20 Most Recent Lenovo TopSeller ThinkCentre M90z AIO Core i3 530 293GHz3GB500GBDVDRW23FHDbgnGigNICW7P PC Desktop Questions & Answers
What menu? What does the pop up say? Just " lock menu"?
Lenovo TopSeller... | Answered on Dec 19, 2012
Please check with the Seller or use the Serial No. to track the exact info of your Laptop.
Lenovo... | Answered on Sep 20, 2016
Back up all your data and do a system restore
Lenovo... | Answered on May 13, 2016
I would replace the whole power supply. You don't want to give it a chance to short out the board. If this is a just a run of the mill business machine the power supply should only be around 50.00 or less depending on where you find it.
Lenovo... | Answered on Apr 14, 2016
If the pins are bend straighten it using squeezer
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below:
-Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'.
-In the search box, type 'troubleshooter', and then click 'Troubleshooting'.
-In the left pane, click 'View all', and then click 'Display Quality'.
GuruAid.com
Lenovo... | Answered on Mar 21, 2016
I read that the motherboard for this PC is an Asus P67 B3
(http://www.techspot.com/review/424-lenovo-ideacentre-k330/)
(However the picture of the inside of the PC doesn't look like the picture o the Asus website, so this may not be right, although the schematic in the Lenovo hardware replacement guide does http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/K330/Lenovo%20IdeaCentre%20K3%20Series%20Hardware%20Replacement%20Guide%20V4.0%20(English).pdf)
The information you need ought to be in the manual which is available as a download from the Asus website here
https://www.asus.com/Motherboards/P8P67/HelpDesk_Manual/
19.January.2015
Lenovo... | Answered on May 13, 2015
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Lenovo... | Answered on Apr 05, 2015
Then you have to go back to the distributors of this Linux distribution and list the drivers for the items you need.
Linux drivers are open source programs, so the drivers from one computer can be complied into another distribution, if they use the same chips.
The manufacturers such as Lenovo rely on third parties to provide any software that they do not support, they do not have to write them.
Lenovo... | Answered on Feb 25, 2015
Check that you have the right keyboard language enabled. Hold Windows key and press Space until it says English (US).
Lenovo... | Answered on Feb 21, 2015
We need more info. Mouse and keyboard error doesn't help.
Lenovo... | Answered on Feb 11, 2015
The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
Lenovo... | Answered on Jan 05, 2015
The Quick Contacts button on the left will lead you to "Open Full Contacts". If none are listed, you need to export them from AIM or wherever they currently reside, as a CSV, TXT or LDIF file, then Import using the Tools button within AOL Mail.
Lenovo... | Answered on Jan 03, 2015
If there's a manual for the motherboard then it should be here: http://support.lenovo.com/gb/en
Lenovo... | Answered on Nov 07, 2014
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
Lenovo... | Answered on Nov 03, 2014
Hi, I just found this helpful user manual for ThinkCentre PC's in Adobe Reader (PDF) Format:
http://www.lenovo.com/shop/americas/content/user_guides/m58_m58p_ug_en.pdf
To access the ThinkVantage Tools, click "Start," then "All Programs," then "ThinkVantage Tools." To access the ThinkVantage Productivity Center, click "Start," then "All Programs," then "ThinkVantage Productivity Center."
The manual warns that these applications are available only on Lenovo ThinkCentre PC's with Windows 7, an internal hard drive, and Lenovo software pre-installed. I presume however, that you meet all of those criteria. I hope this is what you are looking for. Thank you.
Lenovo... | Answered on Oct 27, 2014
Hold down the control key and use the mouse scroll wheel to adjust the text size.
Lenovo... | Answered on Oct 07, 2014
Lenovo TopSeller ThinkCentre M90z AIO Core i3 530 293GHz3GB500GBDVDRW23FHDbgnGigNICW7P PC Desktop Logo
Popular Tags
2 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkCentre Lenovo
  • ThinkCentre Lenovo
Most Popular Question
thinkcentre m90z lock menu problem
  • Computers & Internet
