20 Most Recent
Toastmaster TP424 4-Slice Toaster Questions & Answers
Why will my Elements not turn on?
If you definitely have power at the elements, then if they are not heating they must be damaged - just check there is no cutout or safety device after the point you are testing for power.
My guess is that new elements will solve the problem
Please post again if you need info on getting/fitting replacements
http://www.toastmastercorp.com/PDFs/Specs/toasters/FM128.pdf
This link gives contact details etc. at the bottom.
Hope this helps :)
Right side only one heating element works very hot
You can repair the other side heating element in a electrical shop or by ur self if u have the skills. Mostly the element breaks of due to food hitting at it when ejected or inserted.
Thankyou
Appreciate a good rating from you.
I have a Toastess Waffle Iron Model 551, I found
From the toastess recipe pamphlet that came with my waffle/ sandwich maker in the early '80s
2 cups all-purpose sifted flour
1 tbsp sugar
3 teaspoon baking powder
1/2 teaspoon salt
3 eggs, well beaten
2 cups milk
1/2cup butter or margarine, melted
Mix flour sugar baking powder and salt in a large bowl. Beat eggs and milk together. Add to dry ingredients. Together with melted butter and beat only until batter is smooth. Follow instructions to baking.
Yields 12 waffles
Electric kettle stop working
Disconnect the wire and open up the thermostat if its not heating up the water or not automatically stops after heating. Replace your Electric Kettle Thermostat with a new one. Because most of the problem occurs when your thermostat does not work properly. And about a 10 percent chance is your heating Element is getting wrong.
