20 Most Recent Fender Squier Classic Vibe Telecaster 50s Vintage Blonde Questions & Answers
check at seymourduncan.com...your humbucker needs to have 4 conductors in order to tap coils...which is what I presume you want to do with the push/pull...
relative pickup wire colors:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=coil_splitting
now match the Fender colors to the Seymour Duncan wirs and check this out:
Fender Squier... | Answered on Apr 23, 2014
Go to Stewart MacDonald website for luthiers.
Fender Squier... | Answered on Mar 03, 2014
That guitar features two single coil pickups when stock. If, however, you or someone else installed a 4 conductor humbucker in the neck and you want to access other tonal options, check out the Seymour Duncan web site- they have tons of easy to understand diagrams- you just need the soldering skills to make use of them!
Make your selections on this page and good luck!
Fender Squier... | Answered on Mar 01, 2014
This could be the speakers that have become damaged or the final audio transistors. It would require you to have a way to test them to be sure which it is. The speakers can be tested with an OHM meter to see if the voice coil is bad. To test the amplifier you would need more specialized equipment like a scope, audio watt meter or component tester, To use the component tester or to perform service on the unit you will need to be able to solder.
Fender Music | Answered on Nov 07, 2020
I'm an engineer, not a musician. The device is a frequency meter set up to display the musical note input to it. If you pluck a C flat and it shows an A you need to tune your instrument till it shows a C flat. You will have to refer to the manual for operation and modes.
Fender Music | Answered on Dec 04, 2019
yes check the fuse . there is generally a fuse for power switch and that sounds like what your having trouble with. hope that helps you out.
Fender Music | Answered on Sep 27, 2019
Does it still have a hum/buzz when NOTHING is plugged into the INPUT? If so, you MAY have a tub going bad. If the noise is only there when you have your guitar/effects, etc. plugged in, then the problem is the guitar grounding or effects faulty...
FIRST: When the amp is "cool", UNPLUG THE AMP POWER CORD FROM THE WALL! ! ! ! Then CAREFULLY remove and reseat the tubes one at a time. Be sure to insert back into the socket correctly. You MAY just have a bit of corrosion on the tube "pins"....
SECOND:Don't plug anything into the amp, turn on and warm up. GENTLY tap one tube at a time with a WOODEN pencil. DO NOT USE anything metallic (like a screwdriver....) and be VERY gentle. If the noise increases or decreases, you probably have a tube going bad...
That's all I have. If this doesn't cure the issue, best take it to a repair shop . . . .
While it is possible (probable) it is caused by the AC mains modulating the output due to a power supply fault, it could be caused by inadvertently creating a hum loop due to poor grounding - check out the link below...
https://www.google.com/search?q=hum+loop+audio&rlz=1C1CAFB_enGB673GB676&oq=hum+loop&aqs=chrome.4.69i57j0l5.8500j0j8&sourceid=chrome&ie=UTF-8
first checkout your cable
if you still have problem , change you pickup
bring to a music shop fixya doesnt do appraisals
Fender Music | Answered on Jul 01, 2019
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
Fender Music | Answered on Jun 12, 2019
The Fender Hot Rod Deluxe has been around since 1996
Fender Music | Answered on Apr 06, 2019
You have to get the volume pot cleaned and lubricated. If not a quick replacement should do.
Fender Music | Answered on Feb 11, 2019
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
  • Number of Footswitch Buttons: 1
  • Manufacturer Part Number: 0994052000
  • It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
  • Fender Music | Answered on Jan 18, 2019
    Fender Squier Classic Vibe Telecaster 50s Vintage Blonde Logo
    7 questions posted
    Top Fender Music Experts
    Larry Stiles
    Larry Stiles
    Marvin
    Marvin
    Are you a Fender Music Expert? Answer questions, earn points and help others
    View Most Popular
    Fender Music
    • Fender Music
    Most Popular Question
    push pull guitar diagrams
    • Music
