20 Most Recent
Safe International Electronic Digital Safe Box Gun Home Security 14x10x10 Questions & Answers
Just put new batterys in safe . but safe will not
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
1/9/2011 4:26:06 PM •
Safe...
Answered
on Jan 09, 2011
Bumil safe
Hope my experience helps someone: followed instructions above, removed batteries, unscrewed 2 Phillip screws. This allowed the electrical assembly to be lifted off the door. No override key hole or anything. What I did notice though was that the negative (black) soldering connection point was completely corroded. Greenish white stuff. The red positive side was fine. Used a flat head screwdriver to scrape gunk off to expose the metal contact. Then also exposed some of the black wire (shiny metal). Placed fresh batteries back in, and pressed the freshly exposed contact and wire together. Voila, the unit beeped and came nack to life. Entered combination, managed to unlock and open the safe. Re-soldered the contact and wire together. Fixed. Just simple corrosion resulting in loss of electrical conductivity. Crude electrical system, easy fix.
1/5/2024 2:02:56 PM •
Safe...
Answered
on Jan 05, 2024
Low batteries in my safemark safe- how do i open?
e-bar is not a battery problem, it means the door lock is jammed, either use a rubber malet or your balled up fist and after inputting the code to unlock hit the door of the safe all around the key pad as hard a you can, your will hear the rods moving and unlocking the door. Hope this helps. I know it works I do this at the hotel I work in.
10/2/2013 5:12:49 AM •
Safe...
Answered
on Oct 02, 2013
