20 Most Recent NTI Backup Now EZ Software Questions & Answers
0answers
I purchased two NTI Backup Now EZ backup drives
You will have to contact the company directly. Each system is different enough that you will need their help troubleshooting the issues.
9/12/2013 3:58:51 PM • NTI Backup Now... • Answered on Sep 12, 2013
I originally downloaded NTI Backup
Hello bobdurack
I'm not shure this is the solution but it's a possibility : has the letter of your external Toshiba eventually changed ?
Regards ,
fanaudi .
3/29/2011 7:05:10 AM • NTI Backup Now... • Answered on Mar 29, 2011
I am using NTI Backup Now EZ 7 on Windows 10. Where is the 'overwrite old backups' option?
If you're using NTI Backup Now EZ 7 on Windows 10, you may be wondering where the 'overwrite old backups' option is. Here's a quick guide to help you find it. Open the NTI Backup Now EZ 7 application. Click on the 'Advanced Options' tab. Click on the 'Backup Options' button. In the 'Backup Options' window, select the 'General' tab. Under the 'Backup Options' heading, you will see the 'overwrite old backups' option. Select the 'overwrite old backups' option and then click 'OK' to save your changes. I hope this helps!
11/22/2022 4:44:25 PM • NTI Computers &... • Answered on Nov 22, 2022
I am using NTI Backup Now EZ 7 on Windows 10. Where is the 'override old backups' option?
The "override old backups" option is located in the "Settings" tab of the NTI Backup Now EZ 7 application. This option allows you to choose whether or not to overwrite existing backups with new ones. If you have this option enabled, your backups will be overwritten each time you run a new backup. If you disable this option, your backups will be kept separate.
11/15/2022 5:49:55 PM • NTI Computers &... • Answered on Nov 15, 2022
A windows system change wiped everything off my computer but I can't get my NTI to restore. The external hard drive shows over 240G used so it must have something on it. How do I restore?
Try downloading the program called "Recuva" by Ccleaner it should help recover everything you have, also try going to your drive letter and right click and it should say fix disk errors then just fix the disk errors those two things should work
10/2/2019 5:57:44 PM • NTI Computers &... • Answered on Oct 02, 2019
My computer crashed, how do I recover my NTI Backup Now EZ program? My computer can't find the NTI setup.exe.
Many people confuse system back-ups with system restore and/or recovery programs. They are very different. A backup makes a copy of selected (or all) files and stores them to a disc, tape, hard drive, or other device that will allow you to protect your files in the event of data loss. Say you accidentally delete an entire directory instead of a single file. Your backup would allow you to re-load that directory. System restore/recovery files are used in the cases where you either want to reload the computer back to a certain condition (factory restore), or need to completely recover your computer in the event of a crash. These types of files usually need one of two things to work. If the recover/restore software was OEM manufacturer supplied, there may be a BIOS routine that, using a hotkey on boot-up, will allow you to access the recovery/restore file. If it is an aftermarket program like your, recovery/restore files usually need to create a bootable USB or CD/DVD that can be inserted on boot-up, and then the files on that device will perform the recovery/restore. If all you have a a system backup, you may have to reinstall the operating system, drivers, and then the backup software. After that, you can use you backup file to recover your remaining programs/data.
9/30/2015 5:19:17 AM • NTI Computers &... • Answered on Sep 30, 2015
The drive database cdrw32.bdb cannot be found
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
9/14/2009 9:19:37 PM • NTI Computers &... • Answered on Sep 14, 2009
Who developed programming language JAVA?
Java was developed by James Gosling, Mike Sheridan, and Patrick Naughton at Sun Microsystems in the mid-1990s.
2/3/2023 3:36:58 PM • Computers &... • Answered 2 hours ago
2answers
I Want To Invest In A Business, What Kind Of Business Should I Invest In And Where?
Small business owners will be envious to possess that type of startup capital. My primary advice is always to clarify how you feel "fast" profits and just what type of risk you are prepared to take to achieve this. Following this publish a new question with those particulars so you receive a complete answer.
2/3/2023 7:55:28 AM • Computers &... • Answered 10 hours ago
Can not communicate with Piczel model 165 IP camera. Do have any info or manuals? thanks.
Question edited for clarity. The is an eBay / Sam's club special made in China. The reviews say to speak to 'Dan'. https://www.samsclub.com/p/165-4pk-p-t-wifi-cam-ir-leds-cut-filter/prod8040049 https://www.google.com/search?q=piczel+165+ip+camera+manual ..
2/2/2023 8:22:17 PM • Computers &... • Answered 22 hours ago
NTI Backup Now EZ Software Logo
Popular Tags
9 questions posted
Popular Products
Top NTI Computers & Internet Experts
Marvin
Marvin
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NTI Computers & Internet
Most Popular Question
purchased two nti backup now ez backup
  • Computers & Internet
