20 Most Recent
Seagate FreeAgent GoFlex Pro 750 GB USB 30 UltraPortable External STAD750101 (Black) Hard Drive Questions & Answers
Just bought the GoFLex Pro 750 GB. I have two
Hi, Thanks for using fixya.
Try this go back in disk management right click on the disk assigned to your GoFLex Choose change drive letter and paths. After you make the change go back in My Computer and see if you can ues it.
Terry
2/17/2011 3:51:32 AM •
Seagate...
Answered
on Feb 17, 2011
Remove any usb devices from your computer other than your Free agent then reboot the computer see if it is reconized and it is useable. Then plug in your other devices one at a time make sure you see the Your device is ready to use. If your Free Agent is not reconized got to Seagate.com search for your device driver. Remember when you want to pull out any usb device make sure you remove it throught windows first. Fastest way is to go in My Computer or Computer right click on the device and choose eject. After the name changes to removable device it is safe to pull our.
Hope this helps,
Terry
2/17/2011 2:12:29 AM •
Seagate...
Answered
on Feb 17, 2011
Seagate freeagent desktop 9nk2-al510
It varies depending on the operating system. You can create a Linux mint DVD and boot that without installing. It will take a moment as it is reading the OS from the DVD then see if you can see it, if so it is OK, if not something is bad or set wrong in the USB hardware system.
1/7/2017 11:26:28 PM •
Seagate...
Answered
on Jan 07, 2017
Seagate Service center in the philippines
You don't need a service centre.
Take the drive out the caddy and plug it into a working computer using a SATA to USB cable. If the drive is functional then you'll be able to read it. If the drive is dead then you'll need to get another drive.
7/27/2016 1:14:06 PM •
Seagate...
Answered
on Jul 27, 2016
External hard drive won't start up
assuming that "wont start up" means that the drive letter is not visible thru windows explorer/my computer, which is already installed and booted from an internal hard drive...
the seagate drives, often, require a patch to work with some windows installs- especially if it is larger than 3 terabytes, and occasionally, if larger than 1 terabyte. if this is the case, the patch is most easily obtained by emailing customer service.
if this is not the case, please provide more specifics as to your computer, your version of windows, and exactly what it is not doing when you say 'not starting"
12/28/2014 11:35:38 PM •
Seagate...
Answered
on Dec 28, 2014
Need freeagent pro driver for window 8.1
If your disk is not working with Windows 8.1 (connect it, and watch to see if there is bubble at the bottom right of your screen which says 'found new hardware', and 'searching for divers' then 'your new hardware is installed and ready to use': this will only happen the first time you connect your HDD to your computer and possibly only if you are connected to the internet)..
If your HDD isn't recognised by your computer, specifically by your computer's USB system, contact Seagate support over the problem.
25.April.20-14Other I
4/25/2014 3:21:37 PM •
Seagate...
Answered
on Apr 25, 2014
Seagate shows there is atleast 30 GB/300GB being
enable hiden files and folder and system files if it is a external hard diskor 1 go to command prompt2 type the drive letter example X:3 you get X :\>4 type the command attrib -R -A -S -H /S /D5 WAIT UNTIL YOU GET X:\> 6 IT WILL SHOW ALL YOUR FILES INCLUDE SYSTEM FILES
10/30/2013 3:11:16 AM •
Seagate...
Answered
on Oct 30, 2013
Unlock password
If it's the system BIOS asking for the hdd unlock password, just open up the computer, locate the cmos jumper on the motherboard, move it from pins 1&2 to 2&3 for about 5 - 10 seconds. Then move it back to its original position and turn the computer on. This should clear any passwords set in the BIOS.
10/25/2013 4:41:57 AM •
Seagate...
Answered
on Oct 25, 2013
