20 Most Recent
Dell Vostro 3700 Laptop Computer (Intel CORE I5 450M 320GB4GB) (BQMC7F52) PC Desktop Questions & Answers
Slow graphics laptop
Possible that PC is hanging up as there isfault on the OS (operating system) or a virus in the OS. Also it is possiblethat the backup battery (CMOS) has low voltage or the memory card is a suspect.In this case you need to check the voltage and also try and swap a memory card.Sometimes the memory card connections can be faulty either on the card or onthe slot. Cleaning the slot and card must be done before you try a replacement.If the PC boots and fails then the hard disc can have bad sectors or iscorrupt. However if there is no result the motherboard also can be suspected.In this case you might need the help of proper tools and equipment support todo a chip level service.It is best to go for a paid antivirussoftware which you can get in a package. Personally we are not recommending anyparticular company but you can try with Avira, Antivir, AVG, Kaspersky. It isalways best to install the antivirus when the installation of the OS isdone. Now before this you can open the internetoptions in the browser and clean all the cookies, temporary internet files,defragment the drives and RESTORE the PC to an earlier set date.
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Wifi hotspot
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
Windows update failure (KB982670)
Believed me you have to reinstall your operating system. I encountered that problem too. I uninstall and re-installed .NET, update windows service packs nothing happened until I reformat the hard drive and install the operating system again.remember format the hard drive first then install the operating system (backup your data first)
How to lock the Window 8 dell laptop
Hi Anonymous,
Try pressing the Ctrl+Alt+Delete keys together and now press lock the computer. However, if this doesn't help do let me know.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
