20 Most Recent Fujitsu LifeBook AH530 NoteBook Questions & Answers
If you have a valid copy of xp pro, then just insert the disk and boot from it when asked. when you are asked about an install, choose a clean or new install and everything will be erased and you will start over. Be advised that you will need to get the lifebook drivers burned to a disk before you start.
Fujitsu LifeBook... • Answered on Apr 25, 2019
1. Turn off the laptop2. Remove the power cord3. Remove the battery4. Dismantle back screws and pop open the cover.5. Locate the Dry cell (Button Cell)6. Remove the button cell from the laptop.7. Wait for 10 Seconds8. Put back the button cell.9. Fix the back cover by re-screwing10. Put back your laptop battery11. Turn on the laptop12. Thats it !
Fujitsu LifeBook... • Answered on Oct 04, 2018
Your problem seems to be from the keyboard. Even if it looks good if the keyboard tape is out of whack or some key is no longer working, it can happen that you say, so I change the keyboard.
Fujitsu LifeBook... • Answered on Nov 21, 2017
Can you locate and download the correct driver for your computer using this link? Drivers Downloads It sounds like you may have installed an incorrect camera driver.
Fujitsu LifeBook... • Answered on Mar 17, 2015
Hi, Go to bios setup by pressing f2 and check that the "internal camera" is enabled. Regards
Fujitsu LifeBook... • Answered on Mar 07, 2015
Place a short on the battery holder's + and - tabs for a minute or two. It has to be on long enough to discharge a capacitor on the motherboard. This will delete the bios password only.
Fujitsu LifeBook... • Answered on Nov 19, 2014
Your display setting does not match.You need to setting the display right way.Or you uninstall and install the VGA (graphics)driver again,and simply restart the PC.
Hope it will solve your problem .
Fujitsu LifeBook... • Answered on Jun 14, 2014
1. Ensure the most recent hardware driver for your operating system. 2. Enable device through control panel, bios menu during system start up, and combination of function keys. 3. Do not have external mic connected.
Fujitsu LifeBook... • Answered on May 29, 2014
Set the screen-resolution to 640-by-480, to see if the blinking stops. If it does, set the screen-resolution to 800-by-600, to see if it this higher resolution is supported. Also, try 1024-by-768.
Fujitsu LifeBook... • Answered on May 16, 2014
lcd inverter are commonly found at the bottom of the LCD screen after you'd remove the edges cover. try to remove the VGA cable from the laptop and see if the screen will blink or flash. thanks
Fujitsu LifeBook... • Answered on Apr 02, 2014
Fujitsu LifeBook AH530 NoteBook Logo
161 questions posted
Top Fujitsu Computers & Internet Experts
Carlo Barzo
Carlo Barzo
Davit Mamyan
Davit Mamyan
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
web cam shows black also in camera test
  • Computers & Internet
