20 Most Recent Kingston 2PK 4GB USB 20 DATATRAVELERI GEN 3 TWIN PK DTIG34GB2P (740617175851) Media Questions & Answers
1. 1. Connect your USB Flash drive to your computer.You can do this by locating an unused USB port on your computer. 2. Locate the my computer icon on your desktop,provided you are running one of the various Windows operating systems. Doubleclick the my computer icon. You will see a drive labeled as removable drive orflash drive. Double click on the drive. Leavethis window open, proceed to next step. 3. 3. Locate the music files that you havedownloaded/save to your computer. Usually the default location will be "My Music" folder under "MyDocuments". Open the folder that you have downloaded/saved your music in. 4. 4. Highlight the music file and right click. Pickthe copy option. Next go back to the window you opened for you flash drive instep one. Right click in this window and click paste. You should now see yourmusic file in this window.
Kingston 2PK 4GB... | Answered on Apr 21, 2020
Try another computer. If it does not format then it is defective. Get a new one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Kingston 2PK 4GB... | Answered on Dec 06, 2014
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive Click start all programs accessories open windows explorer navigate to your data
Right click on the data select copy navigate back to the External Drive.
or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
Once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device
if you need more help with this post a reply Hope this helps
Kingston 2PK 4GB... | Answered on Jan 15, 2013
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Kingston 2PK 4GB... | Answered on Apr 20, 2011
Hi and Welcome to Fixya
You may try to format your USB using the computer disk management tool. Right click on MY COMPUTER then select manage. Make sure that the USB is plug in to the usb port. Go to disk management then look for you Flash drive. Right click on it then click format.
Please reply if you have any questions.
Have a good one!
Kingston 2PK 4GB... | Answered on Feb 21, 2011
Select it on your desktop, right mouse click and change the name.
Kingston... | Answered on Sep 23, 2019
Not knowing the model # makes it difficult to give you a difinitive answer. Kingston's support docs all say that after x mny failed logins the device will have to be formatted.
The default # of failed logins seem to be 10.
I think you're out of luck.
Kingston... | Answered on Feb 05, 2019
pack it in rice for a few days and try again. might work who knows. uncooked rice
Kingston... | Answered on Jun 17, 2017
formate it in you pc
Kingston... | Answered on Feb 12, 2017
First, the basics...
There are three kinds of SD cards (SD, SDHC and SDXC). Not all computers are designed to accept all three types. SD cards can store up to 2GB of data, SDHC can store up to 64GB of data, and SDXC cards can store up to 2TB (terabytes) of data. If you are unsure which types of cards your laptop or computer will accept, visit the manufacturer's web site and look for the specifications for your particular model to be sure. It's tempting to want to buy an SD card with a large data capacity, but it's wasted money if your computer will not work with the high capacity card.
Make sure you have inserted the card correctly (and fully). The card is 'keyed' (with a notch in one corner) so it should only fit into the SD card slot one way *easily*. Obviously you can try to force the SD card into the slot the wrong way, but the position which goes in the easiest is probably the right way. Some devices have a symbol beside the slot indicating which way the card should be inserted. Be careful, though. It is natural to think the the card should be inserted with the manufacturer's label facing up, but I've seen devices where the card should be inserted 'upside-down', contrary to what I thought.
If you are using a Windows computer with a 'recent' version of the operating system (Windows Vista or later), the computer should recognize the card (as a newly attached piece of hardware) and show the card as a new drive letter when you open the Windows Explorer program to view your files and folders.
If the card is new, it should be formatted already and can be used immediately, BUT...your computer may need to have a driver program (software that enables the use of specific hardware items). My laptop, for example, uses a driver from Ricoh to enable the SD card slots, and that driver had to be downloaded from the HP support site and installed before my SD card slots would recognize SD cards.
If you know you have the correct SD card device driver installed, have an SD card that will work with your computer but still do not see the card in Windows Explorer, you can check in the Windows Device Manager to check its status. You can also use the Disk Management features of Windows to check what drive letter has been assigned to the drive. If the SD card has been assigned a drive letter already used by another drive, then it will not be available in Windows Explorer.
If you think any of these last problems I mentioned are part of your issue, reply here and I can see if I can help you further.
Kingston... | Answered on Apr 28, 2016
Take your memory card out of the device and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). NOTE: Some cameras have image protection built into the on-camera software and you may need to configure this there.
Kingston... | Answered on Nov 26, 2014
Put your drive into a USB port on your computer. Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
Your computer may need drivers installed for your flash drive. Visit your USB drive manufacturer's website, find the "Support" page, and download the drivers for your specific drive. Be sure to know what version of your operating system you are running as it may be necessary to ensure you get compatible drivers. Install the drivers and try again.
okay, problem isn't in ur pendrive problem in ur computer, some kind of viruses attack only removable drives, and user didn't find viruses in computer and also antivirus, you should download microsoft security essential here,--- http://windows.microsoft.com/en-IN/windows/security-essentials-download ,
and update this software insert ur pendrive and start virus scanning as a whole computer including ur pendrive ur problem will surely solve
Kingston... | Answered on Jun 27, 2014
It sounds like your files are encrypted (for some strange reason). You will need to figure out how to un-encrypt or disable encryption on the troublesome drive. It might help further if you stated what OS's are on the computers involved.
Kingston... | Answered on Jun 22, 2014
Sounds like there are sectors of the drive are failing. Chkdsk can help mark those as not usable. If drive is old and problems persist then consider getting a new one.
Kingston... | Answered on Apr 25, 2014
Kingston 2PK 4GB USB 20 DATATRAVELERI GEN 3 TWIN PK DTIG34GB2P (740617175851) Media Logo
8 questions posted
Top Kingston Electronics - Others Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Electronics - Others
Most Popular Question
download music save usb
  • Electronics - Others
