20 Most Recent Westinghouse 78127 Industrial Ceiling Fan Questions & Answers
2answers
My fan in turning counter clockwise and there is no switch to reverse it, what can I do?
You need to check what sort of motor it is. Some motors will not go the other way around.
8/2/2017 6:06:39 PM • Westinghouse... • Answered on Aug 02, 2017
2answers
I installed 2 industrial ceiling fans with 5 speed
A regular dimmer switch will not do what you want.  A variable speed switch similar to a dimmer but made specifically to control motor loads may do what you want.  I think it would have to be installed after the 5-speed controller because the reduced voltage may cause problems for that controller.  Maybe you should just replace the controller with a the variable speed switch.
4/28/2010 6:47:08 PM • Westinghouse... • Answered on Apr 28, 2010
2answers
78127 remote switch
With a switch it is always the hot wire (black or red one) that goes through it. If it doesn't work, it may be a faulty switch. They make everything in China now, after all.
4/29/2008 2:20:19 AM • Westinghouse... • Answered on Apr 29, 2008
Mi secadora Westinghouse no prende
English only on Fixya please https://translate.google.ca/?sl=auto&tl=en&text=Mi%20secadora%20Westinghouse%20no%20prende&op=translate Bad switch Bad start capacitor Bad door switch Failed motor Mal interruptor Condensador de arranque defectuoso Interruptor de puerta defectuoso Motor averiado ..
11/5/2021 3:36:58 PM • Westinghouse... • Answered on Nov 05, 2021
2answers
Where can I get an outlet box for my Westinghouse 78556 ceiling fan? It was missing in the fan I purchased.
There is no part like that in the fan kits. If you are talking about the box that is inside the ceiling with wires in it, you use the one that is already there IF IT WILL SUPPORT the weight of the fan. IF not you are going to have to get one or contact an electrician.
10/16/2017 10:54:03 PM • Westinghouse... • Answered on Oct 16, 2017
Need help refitting the tension spring and belt to a Westinghouse dryer
You need to feed the belt around the tensioner first but release the tension from the tensioner. Place something under it to keep it from expanding open and the feed the belt onto the drum. If you get it started you can turn the drum and it will feed itself onto the drum. Once that is done, align the belt visually for straightness and gently release the tension. Voila
8/5/2017 6:02:46 AM • Westinghouse... • Answered on Aug 05, 2017
Westinghouse 78127 Industrial Ceiling Fan Logo
4 questions posted
Top Westinghouse Dryers Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
View Most Popular
Westinghouse Dryers
  • Westinghouse Dryers
Most Popular Question
fan in turning counter clockwise no
  • Dryers
