20 Most Recent Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Questions & Answers
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Shop Vac... | Answered on May 29, 2018
There is a thermo fuse in the field winding under the tape. When it overheated the fuse went bad.
Shop Vac... | Answered on Oct 05, 2014
Remove the hose and lay it straight. Then using a broom or mop handle, push it into the hose and collapse the hose on the handle as far as you can. (Think crinkling your socks to pull them over your feet). You'll be doing much the same as you pull the hose up onto the handle. If you have no resistance from one end, then do the same things from the other end. Then replace the hose onto the vac and turn on the power. Your pushing with the broom/mop handle should dislodge whatever is caught and the suction from the vac should pull it through the rest of the way. I hope this helps. If so, please rate my solution. Good luck!
Shop Vac... | Answered on Dec 22, 2010
No, take the filter off
Shop Vac... | Answered on Jul 10, 2010
Buy any electrical shops.
Shop Vac... | Answered on Mar 04, 2010
ask your local vac shop,they should be abel to get you one. they can help with any questions.
Shop Vac... | Answered on Oct 24, 2009
check your filter
it the round thing hanging from the middle
you may need to clean or replace your filter
you should never leave the filter in while using it as a wet vac that will ruin it immedatly
Shop Vac... | Answered on Oct 09, 2009
try tapping the motor area with a piece of wood or something, damp usage may have seized it up a bit
Shop Vac... | Answered on Jun 24, 2009
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
39 questions posted
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Shop Vac Vacuums
  • Shop Vac Vacuums
Most Popular Question
craftsman brand
  • Vacuums
