20 Most Recent Proficient S12 Subwoofer Questions & Answers
Check the fuse which tends to blow frequently.
Proficient S12... | Answered on Oct 27, 2012
The power supply is working but it is possible that there is no supply to the SUB WOOFER amplifier. It is important to remove and open the unit to probe and confirm.
It can be failure of the inline fusible due to a faulty output driver.
Finally check the subwoofer using a AA cell.
Proficient S12... | Answered on Oct 17, 2011
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
Proficient S12... | Answered on Jul 29, 2011
Call the main office - 877-888-9004.
Proficient S12... | Answered on Jan 18, 2011
Pull the speaker and check the coil with a meter. Should read 8ohms. chances are you have a burnt voice coil. They have a 2 year warranty on subs.
Proficient S12... | Answered on Jan 09, 2011
with nothing connected and the sub turned on....Most subs buzz when the circuitry starts to fatigue. The last time I heard this ..the repair ended up being one of the two fat capacitors inside the sub. I have a means of testing this,,you may not. I am a repair shop with a bit of experience in component level board repair.
Proficient S12... | Answered on May 07, 2010
I too am looking for the solution, I'm hoping I have the wrong power cord which is sending too much power to the sub, my next attempt will be to just up the AMP on the fuse b.c hey it's broken anyway
Proficient S12... | Answered on Nov 30, 2009
It is below the subwoofer A/C plug and you need to pull it out
Proficient S12... | Answered on Nov 22, 2009
This happens to amps/speakers in general. It's not specific to your system. It's caused by momentary changes in power. Please read the following for more detail: Amp causes speaker pop
Proficient Audio... | Answered on Mar 25, 2016
They could be defective but also the charger could be falsely indicating the batteries are charged when they aren't.
Audio Players &... | Answered 19 hours ago
of course not house calls is not part of this forum
Audio Players &... | Answered 2 days ago
This sounds more like a low power situation. The voltage to the unit might be low, and should be measured.
As far as I know, there's no reset for the unit. Disconnecting the power should reset it, if there is one.
Service manual
https://www.manualslib.com/manual/1052795/Luxman-R-113.html
Owners manual
Luxman-R-113-Owners-Manual - vintage hifi
www.vintageshifi.com > repertoire-pdf > pdf > telecharge
PDF and features of your new Luxman R-113. This AMIFM stereo receiver incorporates the latest in high technology features, such as auto seek tuning, 20 random ...
Try a full reset also check fuses sharp usually have two
Audio Players &... | Answered 3 days ago
Proficient S12 Subwoofer Logo
13 questions posted
Top Proficient Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Proficient Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Proficient Audio Players & Recorders
Most Popular Question
no get sub
  • Audio Players & Recorders
