20 Most Recent Proficient C850 Main / Stereo Speaker Questions & Answers
I happen to be in Riverview Fl about 1/2 hour north of you. I just called my local distributor and we would have to special order them. No big deal, it would just take 10 days. They are 40.00 a pair, and are now a composite material that won't "Brownout" on you. I e-mailed Fix Ya's support to get permission to give you my contact info. As soon as I hear from them, I will place another comment.
Proficient C850... | Answered on Nov 11, 2009
This happens to amps/speakers in general. It's not specific to your system. It's caused by momentary changes in power. Please read the following for more detail: Amp causes speaker pop
Proficient Audio... | Answered on Mar 25, 2016
Only 1 playlist is allowed. This is called "favourite".
When playing a song....hold/press the = button.
A popup will appear.
Choose favourite.....and it will be added to your favourites playlist.
I haven't found any other way to create a plylist on this device.
Stu
Audio Players &... | Answered 2 days ago
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics [email protected]
Audio Players &... | Answered 3 days ago
Not all iTunes video can be transferred to iPod, please make sure your video is compatible with iPod. If the video resolution or video bit rate beyond iPod limitation, even though they are mp4 video, you can't upload them to iPod. For example, some iTunes purchased movie are High definition movie, the resolution is too high to play on iPod, you can't sync it to your iPod. For more information about iPod compatible video, you can visit apple official website. Or you may take a look at this step by step direction, it's about how to convert and put video to iPod, it works pretty well for me.
http://www.dvdintoipod.com/how-to-convert-dvd-video-to-ipod.html
Hope it helps. Contact me if you need further assistance.
Audio Players &... | Answered on Jan 20, 2021
It can be a variety of reasons but I feel that your amplifier is shutting off after powering on. There is nothing that can be done from the outside but If you are familiar with basic electronics and can attempt to take a look I can try. Open the set after you have pulled off the power, then look into the set and tighten all the connectors and cords. Power on and see where the click comes and goes off. If the relay is not holding on then your protect circuit is shutting it off. Armed with a multimeter turn on the power and check if the main +B power is coming to the output stages.If there is momentary swithch on , then disconnect power and test the continuity in the output stages. If hsort open the leads to the output section and then power on. If the relay stays we have found the fault. you can go on to change the failed outputs. If however the outputs were tested ok, then your fault could be the relay or the protect circuit, Hold a rely for a moment to see if the amplifier powers on, if so check the relay drive transistor , the biasing to the stage. Try this out and I hope my advice helps. Good day
Audio Players &... | Answered on Jan 19, 2021
No reset! It is purely a powered speaker with lights.
https://images.esellerpro.com/2579/I/61/EE2383STK.pdf
Audio Players &... | Answered on Jan 14, 2021
You can download MP3 songs on the Internet, some sites have free songs, other sites charge to download these songs.
I suggest you Google search for MP3 songs/music you prefer say, Rock, Classic, Country & Western etc.
I Have managed to solve my instant turning off fault. As its been mentioned before, this is a demo mode fault, heres what I did...
Leave the Unit in standby, and press and hold the "system menu" button you should see the words "demo mode" flash up on the display briefly, at this point press the "set" button to enter demo mode selection finally press the "+" or "-" button to turn the demo mode off.
You have to be quick with the remote buttons when getting into the demo mode, might take a few trys.
I'm not sure if this will fix everyones fault, but certainly helped with mine. Good Luck.
Audio Players &... | Answered on Jan 13, 2021
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Proficient C850 Main / Stereo Speaker Logo
1 questions posted
Top Proficient Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Proficient Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Proficient Audio Players & Recorders
Most Popular Question
need replacement grills 2 6 25
  • Audio Players & Recorders
