20 Most Recent
XFX GeForce4 MX 420 Graphic Card Questions & Answers
My computer does not see the GeForce4 MX 420
Try this, uninstall all your video drivers in Device Manager and shut the PC down.
Remove your MX 420 and connect the monitor back to the onboard video ( or previous card ).
Boot the PC and go into the BIOS.
Make sure that you select PCI for the graphics option in the BIOS. You are not using it at this moment, but we want it to work when you do put your MX 420 back in.
Now shut it down and put the MX 420 back in.
When you boot and get the "New Hardware found' message, just cancel it and install the MX420 drivers.
Hope this helps.
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
No sound xfx one
You must set up port in drivers and in windows
analog for speakers and headset, or
digital for hdmi to tv speakers
How to repair msi vr320x with no display?
Does both the port not giving you display did you check the memories is it all fine set also the power you have connected it properly try it in different machine check the PCIE Volts which slot is suitable for your Card on your motherboard.
try the display cables and cooling all ok than i am afraid you need to send it to a workshop or you can fix if you know chip level work so there is An IC if fails or leak it does not give any out put so you need to change that.
Nvidia 9600 gt
Maybe you have set the view to large icons in properties.
