20 Most Recent Goodmans 289NS 14" TV Questions & Answers
The range and the airial antena have trouble recieving the new location air signal.Try buy a new digital antena and install it.Auto tuning it again.Should work fine.
Goodmans 289NS... • Answered on Aug 12, 2011
The important information is the output voltage (12 volts DC) and current (5 amps). You need an adapter with those ratings and a plug with the proper size and polarity to fit the TV. If necessary, you can salvage the output cord from the bad adapter and splice it onto a replacement if you can't find one with the right plug. You need to be careful to get the polarity right or you can damage the TV. Most sets have the center pin positive, but you want to check to be sure. The set usually is marked with the information, and it may also be on the old adapter.
You may be able to find an exact replacement adapter by searching for your specific TV brand and model number and "replacement power adapter". Many adapters are available through eBay sellers. Otherwise just look for a 12-volt 5-amp adapter and change the output cord as described if necessary.
Good luck and thanks for using Fixya!
Goodmans 289NS... • Answered on May 16, 2011
Your best bet is a universal bracket that fits Goodmans and is sized correctly for a 14" TV. An example of this is this, however you can also search online for others that fit what you are looking for.
Goodmans 289NS... • Answered on May 08, 2011
This usually means poor signal , HAD THIS PROBLEM WITH MY MOTHER IN LAWS TV, Take tv to other aerial point in another room ( i brought mother in laws tv home to my aerial ) and do a retune,
This could sort things out.
pete
Goodmans 289NS... • Answered on Nov 09, 2010
goodmans GTV51NZ2DVD i am trying to connect a play station 2 put have no remote control so how can i find the av channel can any one help please
Goodmans 289NS... • Answered on Sep 25, 2010
Hi, try hooking your tv or box up to it and do a channel scan, you got nowt too loose
Goodmans 289NS... • Answered on Aug 04, 2009
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Goodmans 289NS... • Answered on Apr 22, 2009
HHHHMMM Never heard of goodmans But if its a 14" tv those are one sale for 69.00 in K-mart Well the 13 " is. Sounds like the vert output is bad or a capacitor in the vert out curcuit. good Luck
Goodmans 289NS... • Answered on Feb 15, 2009
in your remote control there will be one button calles ASM or auto search mode you press it (or auto) tv will tune one by one channel automatically & it will stop. now from prog. button you can up &down channals. from vol +&- vol up& down. good luck.
Goodmans 289NS... • Answered on Jan 17, 2009
Your son more than likely changed the input source. You may be able to change it back by pressing the channel up/down button or you may have to enter the menu on the tv and change inputs that way. PS's will usually connect using a video input using a red/white/yellow cords. You may also want to ensure the connections are in their proper place as I do not know how savvy your son is at changing the setup over to play his PS. If you use a modulator to connect to the TV-either the PS or aerial- ensure that it is powered up also. I hope this has been of assistance to you and thanks for using Fix Ya. If I can be of further assistance let me know.
Goodmans 289NS... • Answered on Dec 27, 2008
50% trouble of tv is lose connection so, try to re solder it but be care of short circuit
Goodmans 289NS... • Answered on Oct 01, 2008
check the sound section and also check the speaker
Hi Mah, It sounds to me that the tuner in the TV has drifted off tune. Your problem may be solved if you can bring up on the screen the channel bar which goes from 22 to 69, then `scan for channels'. saving the good ones and passing over the poor ones. Also selecting the program number before you save each channel. I do not think anything is wrong with the sound circuit.
Goodmans 289NS... • Answered on Apr 17, 2007
The applicable code(s) would be found in a compatible remote control.
Goodmans... • Answered on Dec 04, 2020
No idea if any of the suggestions below will work. https://quuq.org/forum/index.php?topic=3408.0 https://www.avforums.com/threads/goodmans-ld1510-on-child-lock.812276/ Several postings on the internet found using https://www.google.com did not suggest a certain answer. Please use Comment menu to update your question if you find a way that works for you, or you want to report back on what you have tried already.
Goodmans... • Answered on Nov 01, 2019
What is the exact model number to your TV?
Goodmans... • Answered on May 28, 2019
Goodmans 289NS 14" TV Logo
Popular Tags
20 questions posted
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Kolbrun...
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Goodmans Televison & Video
Most Popular Question
wall bracket
  • Televison & Video
