20 Most Recent Toshiba 8 GB microSD - 1 Card - Class 4 Questions & Answers
2answers
My USB Toshiba 8GB show only 4MB
hi, some part of your flash drive sector might corrupt or bad. the windows operating system automatically repair the flash drive or card , so that's why the unreadable sector or bad sector of the drive will be defrag separately from the operational sector, to be able to secure your files.
11/2/2019 9:28:56 AM • Toshiba 8 GB... • Answered on Nov 02, 2019
Toshiba 16gb flash drive is recognized by the computer but not by my printer
Are you sure that your printer is able to use such high capacity memory flash drives? You did not mention printer board and type. a. Use FAT32 format and retry. b. Use a smaller capacity flash drive.
1/1/2017 1:23:23 AM • Toshiba... • Answered on Jan 01, 2017
0answers
Inverter bus failor
Be the first to answer 11/21/2015 3:22:26 PM • Toshiba... • Posted on Nov 21, 2015Be the first to answer
OH error in toshiba inverter VF S11
Follows are the part of the manual Possible causes • The cooling fan does not rotate. • The ambient temperature is too high. • The vent is blocked up. • A heat generating device is installed close to the inverter. • The thermistor in the unit is broken. Remedies Restart the operation by resetting the inverter after it has cooled down enough. • The fan requires replacement if it does not rotate during operation. • Secure sufficient space around the inverter. • Do not place any heat generating device near the inverter..
5/29/2014 1:28:51 AM • Toshiba... • Answered on May 29, 2014
How recover pendrive original space
Hi Santhosh Go to this website and find your USB stick model and donwload the format software and use it. USB Flash Memory Lineup Andrew
1/9/2014 12:14:15 PM • Toshiba... • Answered on Jan 09, 2014
Reducing memory
at command prompt type chkdsk x/f where x is your pendrive
12/19/2013 11:25:37 PM • Toshiba... • Answered on Dec 19, 2013
8gp pendrive became 4gp
This can happen if you attempt to write or format a high capacity card (SDHC) in a SD card reader / writer.You might be able to undo this if you insert the card in a SDHC card reader / writer. You may or may not be able to retrieve the data on the card however.Sometimes, removing a card or USB drive while data is still being written to the card can cause this too. Again, the data may no longer be accessible - and the full capacity may no longer be available on the device.
11/8/2013 1:12:07 AM • Toshiba... • Answered on Nov 08, 2013
My 8 gp toshiba pendrive has been converted into 4
FORMAT IT WITH FAT32 (DEFAULT)ORMY COMPUTER > CLICK THE PROPERTY OF PEN DRIVE > READY TO BOOST (TAB) > DO NOT USE THIS DEVICE > OK
8/7/2013 8:43:33 AM • Toshiba... • Answered on Aug 07, 2013
0answers
0answers
0answers
0answers
Can we use inverters
Can we f*ck?
9/10/2010 6:25:17 PM • Toshiba... • Answered on Sep 10, 2010
0answers
Toshiba 8 GB microSD - 1 Card - Class 4 Logo
1 questions posted
Top Toshiba Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Electronics - Others
Most Popular Question
usb toshiba 8gb show only 4mb
  • Electronics - Others
