20 Most Recent Shop Vac 333-32-08 Blower Vac Wet/Dry Vacuum Questions & Answers
If the motor housing is all plastic and there is no metal the user could contact and potentially receive an electric shock from should a fault occur, the ground conductor if fitted, would be connected to the frame of the motor.
Shop Vac Vacuums | Answered on May 03, 2020
Most likely full or clogged. Turning off to protect the motor.
Shop Vac Vacuums | Answered on Oct 24, 2019
there is a float inside vacuum that will prevent the vacuum from sucking water if tank is full.
Shop Vac Vacuums | Answered on Jun 06, 2019
Are you sure your vac CAN safely suck up water? It's not something you want to do if it can't.
Shop Vac Vacuums | Answered on Nov 25, 2018
check amazon, ears parts
Shop Vac Vacuums | Answered on Sep 10, 2018
If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
Shop Vac Vacuums | Answered on Aug 01, 2018
Clean the ball and wipe down the thing that holds down the ball. Take a little bit of WD40 and spray a little on the ball and holder. Try that.
Shop Vac Vacuums | Answered on Jun 20, 2018
if you are using vac to suck water the ball is a safety device. you must shut vac down and wait you should hear ball drop, if the vac is not in upright position he ball will close shut vac down and wait
Not likely.The on-off switches are cheap plastic, and you will likely find the switch, the plug, the wire, or the motor has died.
Sorry.
Shop Vac Vacuums | Answered on Jun 04, 2018
what vac ?
Shop Vac Vacuums | Answered on May 11, 2018
Some models have a fuse that blows but it is not replacable.
Shop Vac Vacuums | Answered on Feb 27, 2018
Shop Vac 333-32-08 Blower Vac Wet/Dry Vacuum Logo
4 questions posted
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Shop Vac Vacuums
  • Shop Vac Vacuums
Most Popular Question
very old 6 gallon wet dry shop vac now
  • Vacuums
