20 Most Recent
Hitachi 57TWX20B 57" Rear Projection Television Questions & Answers
3d pink and green shadows
Most likely the STK-392-110 CONVERGENCE CHIPS ARE GONE.
Do not jump off the deep end an if you can solder I can help.
Repair parts cost under twenty five dollars on the internet.
The more you tell me the better I can help you.
Look at my solutions here and my record; I have fixed hundreds of Hitachi sets with this kind of problem.
If one of the chips is bad the set will never adjust.
Tell me what you can and Before you rate this information let me know you skill level and if I can still assist you.
SD TECH
My TV picture looks 3-D
Hi pamkusche,
If the symptom didn't cure by convergence adjustment through remote control, this is an indication of faulty convergence board inside. The most common defective parts are the IC's and some of the resistors. If this parts will be replace with new one your unit will back to normal again. Also bad solder joints is going to consider in that board. You may replace the entire convergence board for your convenient. If you can't do this yourself, I would advice you to look for a qualified technician to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
TV screen is black but power button lights up. No
you need to open the tv up and take out the internal fuse or fuses...go and get the right type of fuses...(the fuses will be made of glass and the same size of a plug fuse) DO NOT USE PLUG FUSES....if that fails then you need to take it to the tv repair man
No video from any input. No menus on screen.
No picture or OSD (menu) means your tubes are not lit which means high voltage failure of some sort, can`t help any further on a forum like this, hv circuit needs to be looked at by a tech, gl, video-tek
House breaker triped I reset it but now my Hatachi
hi, you might get lucky and have a locked up micro, un-plug the ac cord for 1 minute and then plug back in, this will do a hard, set-re-set of your tv. If still dead then power supply has been damaged and you`ll need a tv tech to diagnose it, good luck, video-tek
Hitachi 57TWX20B powers on ( but no picture or sound)
f you had multiple power outages, i would contact the power company
or/and insurance company and it should be covered under that, but
sounds like power supply problem if you had power surges
if lighting cause it then it could be anything.
HITACHI BIGSCREEN TV MDL 57TWX20B
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Hitachi shows double image and then no picture or sound.
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hitachi stopped working
conversion ics are not working making the set go ino shut down,, only a technicia can repair
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12.
Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1.
Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
10/13/2023 9:21:56 PM •
Hitachi...
Answered
on Oct 13, 2023
