20 Most Recent BFT R93524500001 - Swing Gate Kit, Single, 16-1/2 Ft Questions & Answers
It means that it has not accepted it ie not compatable or damaged taken too long to do the prcedure or wrong procedure hope this helps
BFT R93524500001... • Answered on Mar 07, 2016
It means that it has not programmed your new remote ie not compatable with your system or damaged hope this helps
The opener may have been mounted improperly or may have slipped from it's original mounting location. You may not be able to make an adjustment because the arm is already fully extended. You may have to re-position the gate opener. Fixya doesn't do repairs. Posting a question here is like calling the public library for an answer that they can look up.
BFT R93524500001... • Answered on Feb 14, 2015
How to Replace Double Glazing in uPVC WINDOWS Cheaply replace blown double glazed window panes in uPVC windows following this video. You just need to look for a local double glazing supplier. Look in local directories for uPVC or Glass manufacturers or suppliers, or use the Internet. Some also deliver to your door. Save a fortune by doing it yourself! Go to this youtube video: https://youtu.be/hyn8BQXgquE or search on google for "comeinhandynow double glazing"
Home Fencing • Answered on Apr 10, 2021
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
Home Fencing • Answered on Dec 24, 2020
Hiya, When your painting iron its all about the primer, this helps its withstand the elements. Make sure you also remove any existing rust! Here is a good example of how to paint a iron fence. Let me know if you have any questions imgbin_fence-gate-wrought-iron-steel-png_yt244huw-undefined-undefined-0.png
Home Fencing • Answered on Aug 25, 2020
The timing relay has to be setted right. There is a time control on every unit,. 1-[Distance has to be set right before setting time relay] 2-(opening time and closing time has to be set accordingly to ur safety and wanting)
Home Fencing • Answered on Mar 27, 2019
Do you have sensors that stop the gate closing on people or cars ? If so put your ear near the sensor but not inline with the opposite one. Now gently wave your hand in front of it .... if there is no click then something is obstructing the beam. Sometimes spiders get inside and spin that candy floss type web in there .
Home Fencing • Answered on Mar 18, 2019
The first place to look is your receiver. This is the device, often separate from the actual gate operator, that responds to your transmitter. Stand next to the gate operator and you should hear a small click coming from the receiver when you or someone else pushes the button. You can sometimes find the receiver by following the antenna cable back to it. If it does not have an external antenna, look inside the operator box for either an antenna screwed into the receiver or a wire hanging from a plastic box. If you hear the click and the gate does not open, the possibilities grow exponentially so we won't try to address every possibility here. If you hear a click when you are close, but not when the transmitter is triggered at a distance, check the antenna. If you don't hear the click, then either the remote has lost programming (this often happens with rolling codes transmitters when they are not used for a long time), or the receiver is not working. Check to make sure the receiver is getting plenty of power power using a meter. It should read at the recommended voltage or a bit higher. Usually around 24 volts but some receivers can work down to 12 volts. If it gets plenty of power and the remotes have been programmed back in, consider replacing the receiver.
Home Fencing • Answered on Mar 08, 2019
remington model 476 power nailer
Home Fencing • Answered on Oct 19, 2018
you can find one via the internet. doh.
I think you should hire a competent electrician. your question indicates you aren't qualified or competent to work on electric power, and it could cause a fire.
look it up on the internet and get the right answer, complete and fully described.
High energy bills is a very common problem. Every home owner or tenant wish to save energy to lower energy home energy bills. There are different ways to lower your home energy bills. I am going to share a blog post which will guide you to do it properly.
These days' people are becoming very much self-dependent, and as a result, they do a lot of things by themselves. One such thing that people do quite commonly these days is fencing. They love to install their own fences, but it is important that you do it the right way. You must also be aware of when you should and shouldn't put up a fence. This will prevent you from facing legal consequences. Getting back to the point, 5 simple steps are involved in installing a fence. The first step is to determine the poles for fence posts. You have to be careful when you are placing the post. Make sure you have dug the holes deep enough to avoid accidents. Then attach rails to the fence post and the last step is to install the fence boards. You can also take a look at to know more information.
on Mar 19, 2018 • Home Fencing
Tip
BFT R93524500001 - Swing Gate Kit, Single, 16-1/2 Ft Logo
3 questions posted
Top BFT Home Fencing Experts
ray gallant
Tom Chichester
Are you a BFT Home Fencing Expert? Answer questions, earn points and help others
View Most Popular
BFT Home Fencing
  • BFT Home Fencing
Most Popular Question
bft phobos bt gate opener problem am
  • Home Fencing
