20 Most Recent Shop Vac 925-13 Canister Wet/Dry Vacuum Questions & Answers
10. You will find four casters (Figure B) and a dolly (Figure C) with your wet/dry vacuum. Assemble as follows:
11. If the casters are not already installed in dolly, insert casters into bottom of dolly by placing stem of caster into holes provided. Ap- ply pressure and twisting motion until casters snap into place (Figure 1).
12. With cord disconnected from receptacle and tank cover removed, turn tank upside down so that bottom is facing up.
Shop Vac 925-13... | Answered on Sep 17, 2018
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Shop Vac 925-13... | Answered on Mar 20, 2017
There is a hidden thermo fuse in the tape on one of the field windings. If it overheats that fuse will blow and the motor won't run until replaced.
Shop Vac 925-13... | Answered on Oct 05, 2014
Just use the sponge filter, if wet dust goes through the blades, it will build up, throw it off balance and the vacuum blades will break loose from the shaft.
You should have two ports on the shopvac. One that is basically your vacuum and one you can use as a blower. Your hose will fit on both connectors. So yes, it would both **** and blow. This is called a "blow-through" system.
Shop Vac 925-13... | Answered on Jul 30, 2011
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Shop Vac 925-13... | Answered on Jun 23, 2011
To PETMOMBR I recently had the same problem, I contacted Emerson Tool Co to see if a replacement for the blow wheel is available,and sadly it is not. I was told that the Rigid vacs do have replacement parts and some with a lifetime warranty.
Had my vac for approx 10 yrs, I would say I got my moneys worth. In all, I'd say it's a toss, time to get a new one.
Doghairsucker in Glendora, CA
Shop Vac 925-13... | Answered on Jun 13, 2011
Sounds like the brushes on the motor are wore and burning up the armeture,,how old is it?
Shop Vac 925-13... | Answered on Mar 07, 2011
Too much water in the unit causes what you describe. Water should be drained and the unit completely dried between water events, or unit will rust and have shortened life.
Shop Vac 925-13... | Answered on Jan 22, 2011
Usually this is from a compromised liner.
Have the well pipe re-lined.
They usually just put as smaller O.D. pipe in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Shop Vac 925-13... | Answered on Sep 05, 2010
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
57 questions posted
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Shop Vac Vacuums
  • Shop Vac Vacuums
Most Popular Question
just bought shop
  • Vacuums
