20 Most Recent Hitachi 65TWX20B 65" Rear Projection Television Questions & Answers
Found L306 was open. B+ to pins 21,22 of PFC2 at the FC Cont tact me for a link to the full service manual.
Hitachi 65TWX20B... • Answered on Feb 28, 2014
yes that means the convergence ics are going bad. tubes are usually weak at that point. money pit.
Hitachi 65TWX20B... • Answered on Mar 24, 2011
This screen assembly is a little pricier than others I've seen. Average price for just the screen is around $750-800. part number is KR02555
Bill W
integrityhomeworx.com
Hitachi 65TWX20B... • Answered on Mar 14, 2011
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Hitachi 65TWX20B... • Answered on Jan 21, 2011
its a failing optic block unit other wise known as a color wheel ok use ebay to find replacement with your model and brand
Hitachi 65TWX20B... • Answered on Jan 03, 2011
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Hitachi 65TWX20B... • Answered on Nov 15, 2010
I may have this I will have to check. my Email is [email protected]
Hitachi 65TWX20B... • Answered on Nov 08, 2010
You do if you are trying to get tv off of an antenna. If you have cable or satellite tv, your service provider will then have some sort of box to receive the tv channels. Let me know if you need anything else.
Benjamin
Hitachi 65TWX20B... • Answered on Nov 04, 2010
The magic focus button don't work.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Hitachi 65TWX20B... • Answered on Oct 15, 2010
The problem with your set is very common and is known as a convergence fialure. What needs to be done is the convergence amplifiers have to be replaced and any resistors or fuses that went bad. To do this repair you will need testing and soldering/desoldering equipment. If you call a repairman they should charge around125-250 us dollars to do this repair. This set is too big to move so the housecall is probably extra. If you have the set repaired it can easily last another 10 years. Hitachi big screens are amoung the most durable and problem free of all sets ever built. Good luck, Russmann.
Hitachi 65TWX20B... • Answered on Jun 14, 2010
you local service center can usually get you a part, as long as its available. you can try to pop off the grille and clean with water, maybe take outside and blast it with a hose, not a perfect fix but might improve your situation.
Hitachi 65TWX20B... • Answered on Jun 01, 2010
RK42-2.7ohms
RK46-2.2
RK50-3.3
RK58- 3.9
RK62-3.3
Hitachi 65TWX20B... • Answered on May 03, 2010
maybe a tube board defective, not the tube, the older models has better electronics quality circuit than the new ones, but you can send to repair and ask for how many will cust to be repaired, and the same time seek price for new one, and send to repair is less than 50% of new one.
Hitachi 65TWX20B... • Answered on Jan 02, 2010
This model was first made around 2002. Does the power light on the front come on and stay on?
If it does--these sets had a problem with three relays on the power board--with the set unplugged remove the back cover and follow the power cord to the power supply board----the relays are on that board--sometimes one or more will stick open and not function---they are about 1 inch wide and 1/2 inch tall and black in color (they will have printing on top of them showing voltage and type)
What I have done in this situation is with the back off use a plastic handle from a screwdriver and tap on all of them---if the set then comes on and works one of them is intermittent--- they are pretty cheap parts and the best way is if you tap and the set works remove the board and replace all of them (four leads connect each to the circuit board).
I hope this helps you and if you have questions reply to this post here and I will assist you.
SD TECH
Hitachi 65TWX20B... • Answered on Oct 01, 2009
OK, the first of these sets was made in 2002 and it uses two convergence IC chips---some use a STK-392-110 AND A STK-392-150-----THE 150 is a higher current (more heavy duty version of the 110) I would replace both with STK-392-150's---YOU can buy both chips on Ebay for about 14 dollars plus shipping---sometimes there will be a bad resistor near one of the chips (taken out by a bad IC)
The reason these chips fail (they are black and about 2 1/2 inches wide and 1 1/2 inches tall) is that a white grease to transfer heat from them to the metal heat sinks they are bolted to---dries out from the heat and after 5-8 years one chip reaches a point where it cannot move the heat fast enough and it goes!
You can locate the chips inside the set---they will have the STK numbers printed on them in white---I do not know if you have the skill to do this repair yourself---if you do you can save some real money----
If you do not have the skills to do this find someone in your area who has done this before--most shops will TRY to charge 300-400 for this kind of repair---I do it here for 200-250 and do hundreds of them each year---I did 2 Hitachi's yesterday in peoples homes.
If a shop says: "it has to go to the shop" keep looking---any good tech can do this repair right in your home--MAKE SURE WHOEVER YOU GET TO DO THE REPAIR CHANGES BOTH CHIPS! If only one is replaced the other will fail and you will have the same problem again. This kind of repair usually takes about a hour to do---once the chips and any bad resistors are replaced the set is adjusted in a tech menu----SET SHOULD BE GOOD AND NOT HAVE THIS PROBLEM AGAIN FOR 5 to 8 years!
Now is the slow time of year for TV shops--shop around--200-250 is a good investment and you could not replace a set like this for that kind of money
If you have any questions or need more help reply to this post.
I do this here for free so if this has helped you take a minute and give me a vote here.
Regards, SD TECH
Hitachi 65TWX20B... • Answered on Sep 05, 2009
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter.
Hitachi... • Answered on Mar 15, 2021
Hitachi 65TWX20B 65" Rear Projection Television Logo
20 questions posted
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
top screen yellow color drops
  • Televison & Video
