20 Most Recent Hitachi 36UX01S 36" TV Questions & Answers
Enter factory mode, and do a factory settings. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Hitachi 36UX01S... | Answered on Mar 21, 2014
To do a factory reset, you have to enter its service mode. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
the audio is plugged in but your video isn't plug your video in and you should see a picture
Hitachi 36UX01S... | Answered on Aug 30, 2012
You have a vertical output IC that needs repaired. You may need to only resolder the vertical output IC. If then you do resolder, you will need to check and replace any capacitor in the immediate area of the vertical IC. A weak or bad capacitor will heat up the IC, and create rings on the pins under the IC. Also check the solder grounds on any resistor and diode that are immediately near this IC. This will bring your TV back to full view. Thanks for asking and show a few hands of support!
Hitachi 36UX01S... | Answered on Oct 04, 2010
try to replace the vertical ic and resolder the vertical section.
Hitachi 36UX01S... | Answered on Sep 16, 2009
the set will not operate with out proper vertical signal/deflection. you may have bridged pins together when resoldering. use a 25w or 35w soldering iron so as not to lift copper traces from pc board. always use solder wick to remove old solder and DO NOT keep on pad to long. mch
Hitachi 36UX01S... | Answered on Feb 20, 2009
RELACED THE VERTICAL OUTPUT IC ALONG WITH THE CAPACITOR AROUND IT.6 YEARS IS ENOUGH FOR THE CAPACITOR 2 DRIED UP THIS CAUSE FAILURE TO THE IC...
Hitachi 36UX01S... | Answered on Mar 08, 2008
The set has a vertical problem if the line you mention is from side to side ,if the line is from top to bottom the problem is in the horizontal circuit and both can be repairable,a vertical fairlure is a common problem,the vertical IC goes bad and it takes a safety resistor with him to prevent any more damage,the horizontal is rare but it happens too,if you are familiar with tv service you can change the IC but you will need a service manual to identify the part,you can get a manual overnight if you downloaded it at www.servicemanuals.net,if you are not too familiar you should seek the help of a servicer for safety reasons.Let Us know how it goes or if you need more information.
Hitachi 36UX01S... | Answered on Nov 01, 2006
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
Hitachi 36UX01S... | Answered on May 22, 2006
Use code search on your Sudden Link URC to find something that woks. If a search through all codes stored in the URC fails, try a different one.
Hitachi... | Answered 19 hours ago
I am guessing it's an old(ish) TV. As a plasma the chances are that it is on it's way out.
Please Try new cables (HDMI etc)
Hitachi... | Answered on Sep 29, 2020
I don't know but it probably isn't much different to most other tv/remote combinations where commands are given by the remote and carried out by the brain in the tv.
Start by pressing the Menu button and the main menu should appear onscreen and from there use the up, down, left and right buttons to navigate the main menu and the select button to select sub-menus and items from the menu(s) until you reach the section on channel search, installation, etc.
Hitachi... | Answered on Sep 27, 2020
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Hitachi... | Answered on May 27, 2020
Hitachi 36UX01S 36" TV Logo
15 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
need info wont turn
  • Televison & Video
