20 Most Recent Hitachi 35UX80B 35" TV Questions & Answers
Plugged in i have no power..
You could have possibly damaged the micro controller within.If the set come on in cold condition it would reset on it own. In such a case try to reset accordingly... or else you will need expert help
6/29/2010 5:48:06 AM • Hitachi 35UX80B... • Answered on Jun 29, 2010
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
12/21/2007 4:36:38 AM • Hitachi 35UX80B... • Answered on Dec 21, 2007
2answers
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
11/23/2007 4:50:54 AM • Hitachi 35UX80B... • Answered on Nov 23, 2007
2answers
Can't highlight or select digital channels to autoscan on hitachi 51f59a
It sounds like you're experiencing an issue with your Hitachi 51F59A TV not allowing you to select or highlight digital channels for autoscan. Here are a few things you can try to resolve the issue:
  1. Check the TV's settings: Make sure the TV is set to the correct input (such as "TV" or "antenna") and that the channel search or autoscan feature is turned on. Consult the TV's manual or the on-screen menu for instructions on how to access these settings.
  2. Check the TV's connection: Make sure the TV is properly connected to a digital antenna or cable box. Also, check that the cables are securely connected and not damaged.
  3. Check for a firmware update: Sometimes a firmware update can resolve issues like this. Check the TV's manual or the manufacturer's website for instructions on how to check for and install firmware updates.
  4. Try a factory reset: If the above steps don't work, you can try performing a factory reset on the TV. This will restore the TV to its original settings and may resolve any issues with the channel search or autoscan feature. Consult the TV's manual or the on-screen menu for instructions on how to perform a factory reset.
  5. Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
3/18/2023 8:43:58 AM • Hitachi... • Answered 3 days ago
Hitachi 65r8 no backlighting
It's the strips themselves that are bad
2/27/2023 7:32:45 PM • Hitachi... • Answered on Feb 27, 2023
Hitachi L40A105 closed caption
Do you have the captions set for Analog or Digital captions? The advanced setting is only available for digital captions. See https://www.manualslib.com/manual/520286/Hitachi-Alpha-L40a105.html?page=19#manual . I hope this helps. Cindy Wells
1/26/2023 11:49:34 PM • Hitachi... • Answered on Jan 26, 2023
HITACHI AX-M71 MUSIC SYSTEM REMOTE
1/23/2023 11:33:19 PM • Hitachi... • Answered on Jan 23, 2023
8.5tr ductable hitachi in remote red light blinking continues what the reason
count the blinks and refer it from user manual trouble shoot section , you will find the reason
1/19/2023 7:29:04 PM • Hitachi... • Answered on Jan 19, 2023
Hitachi tv black screen ?
but nothing else If your Hitachi television has sound but a black screen, it is likely that either the bulb or the inverter has gone bad. The inverter is a part of the backlight system. If the inverter is not functioning, the backlight will not work and the television will be dark. You should check to see if the bulb needs to be replaced first. If the bulb is working and the inverter doesn't turn on, then you may need to have a technician take a look at the television.
1/6/2023 3:08:36 PM • Hitachi... • Answered on Jan 06, 2023
2answers
I have a Hitachi lcd model 50A3. Won't come on and has the blue light instead of red
Hello, more than likely the set has bad back lights, a very common issue with these sets...sorry. Techman 57
11/5/2022 4:35:45 AM • Hitachi... • Answered on Nov 05, 2022
2answers
How do I get the language settings back to English on My Hitachi TV Please ?
https://www.askmefast.com/How_do_i_change_the_language_to_english_on_my_hitachi_50hxt16u_please-qna7526359.html#q4753135
11/5/2022 4:28:04 AM • Hitachi... • Answered on Nov 05, 2022
My Hitachi 65F59A has a blue tint picture all the time? How do I Resolve this? Thank you
Hi, you would need to use your display settings to change the tint. There might be a tint or a hue option that you can press with the display settings. Thank you.
10/7/2022 6:57:00 PM • Hitachi... • Answered on Oct 07, 2022
Toshiba 55HT1U flash of blue when powering up - no other sign of life
An 11 year set isn't worth repairing, time for a new TV
9/13/2022 11:33:41 PM • Hitachi... • Answered on Sep 13, 2022
HITACHI 55HK6100U SMART TV REMOTE CONTROL CAUSES INTERFERENCE ON PICTURE
There is a post about this issue on the AVI blog. There are several people that have had the issue. No one claims a fix for it though. Seems to be related to HDMI cables and how close they are to the remote extender runs.
8/23/2022 2:15:45 AM • Hitachi... • Answered on Aug 23, 2022
I need an manual for my hitachi WD9000
going to have to navigate with the buttons go into source and change from tv to hdmi you want
8/7/2022 6:06:12 AM • Hitachi... • Answered on Aug 07, 2022
Does anyone know the code to connect my Hitachi RC43141 remote to my Talk Talk remote.
You can't connect a remote control to another remote control, that's not how it works. All remotes that are specific to one device, only have that one code programmed in and only work that device. The exception is cable box and satellite box remotes which can be programmed to work for the box as well as the viewing television for switching on and off, volume and channel selection. https://www.google.com/search?q=talk+talk+remote&rlz=1C1QJDB_enCA643CA644&sourceid=chrome&ie=UTF-8 Have a read of this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
7/30/2022 1:27:05 AM • Hitachi... • Answered on Jul 30, 2022
My hitachi 50v525e won't turn on I have sound but no pic I have blue flashing light and tv shuts off by itself...Do I need an input board or is it called a mother board?
I had that problem once. Read online somewhere to change the projector bulb and watched someone on YouTube do it. Straight forward and quite simple to do yourself. You can order the bulb in the metal cage it comes in and swap it out that way; never touching the bulb, but that's more costly. Even more costly if you bring in a TV tech to do it. The video I watched - the guy just got the bulb only and used the existing metal cage just unhooking the old one and putting in the new one. I ordered just the bulb itself off of Amazon for about $40 and did it myself the same way he did. If you do it this way just be sure not to touch the bulb surface with your hand as skin oils can cause the bulb to burn out much quicker. I used/wore a 10 cent pair of disposable latex gloves when I handled the bulb. The panel were the bulb is located is on the front of the TV, near the lower left side. Very simple to do. Just google/Youtube the model number and you should find videos on how to do it yourself.
7/24/2022 10:05:12 PM • Hitachi... • Answered on Jul 24, 2022
Hitachi HAK610U tv has lost anolog channel
In the USA most analog TV went to digital in 2015, there are a few still in analog but from what I understand they go off later this year.
7/23/2022 6:53:18 PM • Hitachi... • Answered on Jul 23, 2022
Small black box on upper right of screen
go to picture set up and see if pip or other setting activated
7/14/2022 6:15:00 AM • Hitachi... • Answered on Jul 14, 2022
Televison & Video Logo
3 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
plugged in no power
  • Televison & Video
