20 Most Recent Hitachi 35TX20B 35" TV Questions & Answers
Tip
Yes, you can know reprogram your 'menu' (and all else...)
If you have this TV(by the by, the 'best' TV ever made:
I've had mine for over ten years: SN: V5F001130
The original 'remote' was CLU-431UG: no longer available,
but you know that....
Here's the solution and very simple:
Radio Shack '5-in-1' catalog# 15-2200 remote.
does it all.
Menu control: (all functions)
Program able for other machines (over 300).
Hope this helps.
CTJ
on Apr 22, 2008 | Hitachi 35TX20B 35" TV
First make sure that the current Source or Input is set to TV. This is usually the only reason for the error message you see. To select the source, look for a Source or Input button on the original remote. If you have an universal remote with a button with the Source/Input label, you may need to try alternative codes to make the button work. (Power and channel controls will often match across multiple codes for the TV manufacturer.) Alternatively, check if there is a Source/Input button on the TV or a section of the menu system with the function. Once you set this source, try again.
Note: there was a period when manufacturers sold some TVs without tuners. They were labeled HD-ready sets. These can't do a channel scan and do not have an RF antenna jack on the set.
I hope this helps. Please add a comment with the model number of your Hitachi TV for more information on setting the source on your set.
Hitachi... | Answered 2 days ago
Depends on the model number.
Hitachi... | Answered 3 days ago
Under Audio or Audio Settings on the on-screen menu, TV Speakers is set to On. All of the cables physically connected to the TV and the input devices are secure. Switch to a different input device and verify there is sound from the TV speakers (for example, a DVD player or a gaming console).
https://www.ifixit.com/Answers/View/310570/The+sound+on+my+TV+stopped+working.
Hitachi... | Answered on May 17, 2020
It is reporting reduced air flow due to a clogged filter. Swing the case upwards, remove the filter and wash it is soapy water. Rinse, dry and replace it.
See yonder videos
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00iKHgEuCo9ZiAKv6-cznuCodHQQA%3A1588957722275&ei=GpK1Xo6xEI6PtAbs3IHgCg&q=hitachi+air+conditioner+filter+cleaning
Hitachi... | Answered on May 08, 2020
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Hitachi... | Answered on May 07, 2020
What is the problem you faces with this TV? Provide more details, please. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Hitachi... | Answered on Mar 11, 2020
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Hitachi... | Answered on Feb 28, 2020
Without a remote control, you can't unlock it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
Hitachi... | Answered on Feb 12, 2020
Soooo...execute it
Hitachi... | Answered on Jan 26, 2020
Simple answer to volume problem i have found there is a demo button on the tv which automatically turns everything down.
Hitachi... | Answered on Jan 24, 2020
The applicable code would be found in a compatible remote control.
Hitachi... | Answered on Dec 28, 2019
Televison & Video Logo
Popular Tags
1 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
need v cable cable hitachi bx35a dvd
  • Televison & Video
