20 Most Recent Hitachi 27MM20B 27" TV Questions & Answers
You would need the remote control to select the MENU, then LANGUAGE.
Hitachi... | Answered on Nov 11, 2020
Use code search on your Sudden Link URC to find something that woks. If a search through all codes stored in the URC fails, try a different one.
Hitachi... | Answered on Oct 29, 2020
I am guessing it's an old(ish) TV. As a plasma the chances are that it is on it's way out.
Please Try new cables (HDMI etc)
Hitachi... | Answered on Sep 29, 2020
I don't know but it probably isn't much different to most other tv/remote combinations where commands are given by the remote and carried out by the brain in the tv.
Start by pressing the Menu button and the main menu should appear onscreen and from there use the up, down, left and right buttons to navigate the main menu and the select button to select sub-menus and items from the menu(s) until you reach the section on channel search, installation, etc.
Hitachi... | Answered on Sep 27, 2020
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Hitachi... | Answered on May 27, 2020
First make sure that the current Source or Input is set to TV. This is usually the only reason for the error message you see. To select the source, look for a Source or Input button on the original remote. If you have an universal remote with a button with the Source/Input label, you may need to try alternative codes to make the button work. (Power and channel controls will often match across multiple codes for the TV manufacturer.) Alternatively, check if there is a Source/Input button on the TV or a section of the menu system with the function. Once you set this source, try again.
Note: there was a period when manufacturers sold some TVs without tuners. They were labeled HD-ready sets. These can't do a channel scan and do not have an RF antenna jack on the set.
I hope this helps. Please add a comment with the model number of your Hitachi TV for more information on setting the source on your set.
Hitachi... | Answered on May 22, 2020
Under Audio or Audio Settings on the on-screen menu, TV Speakers is set to On. All of the cables physically connected to the TV and the input devices are secure. Switch to a different input device and verify there is sound from the TV speakers (for example, a DVD player or a gaming console).
https://www.ifixit.com/Answers/View/310570/The+sound+on+my+TV+stopped+working.
Hitachi... | Answered on May 17, 2020
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Hitachi... | Answered on May 07, 2020
What is the problem you faces with this TV? Provide more details, please. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Hitachi... | Answered on Mar 11, 2020
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Hitachi... | Answered on Feb 28, 2020
Without a remote control, you can't unlock it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
Hitachi... | Answered on Feb 12, 2020
My tv say execute channel scan
Hitachi... | Answered on Jan 26, 2020
Simple answer to volume problem i have found there is a demo button on the tv which automatically turns everything down.
Hitachi... | Answered on Jan 24, 2020
Televison & Video Logo
0 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
need v cable cable hitachi bx35a dvd
  • Televison & Video
