20 Most Recent Diesel Jlg Aerial Work Platform S2 Liftlux Diesel Scissor Questions & Answers
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
Diesel Jlg... | Answered on Aug 09, 2018
https://www.youtube.com/watch?v=m1KyGZR-v5Qhttps://www.youtube.com/watch?v=m1KyGZR-v5Q
Diesel Toys | Answered on Apr 17, 2020
go to a diesel specialist shop with the old one as a sample and you will get one
gp to a tractor servicr agent to get one
if it is plastic , then it is a special fuel resistant plastic hose
Diesel Toys | Answered on Mar 21, 2018
03281 ..... FFR ....................Input request single H (group change switch)
https://www.balticdiag.com/files/resources/MAN_fault_codes_truck_diagnostic.pdf
Lots of information, but in polish and russian. Use Google Translate
FFR 03281 Google Search
Diesel Toys | Answered on Nov 23, 2017
it will be in the owners manual or available from the service dealer
may be shell diesel rotella 20w-40 would be ok
Diesel Toys | Answered on Mar 05, 2017
difficulty in find a web page that has the codes properly explained
one site I found ---techtransa.It has a list or the numbers before the under score and what the fault areas are
To get there I went google and typed in--mandiesel model tga-18-350 fault codes--
there are other pages that make reference to fault codes but are not specific to your model
reading around the fault codes are specific to man and it seems that a normal obd-11 scanner will not be accurate
you might have time to down load a good site when you find one , but as I consider a heavy vehicle should be out earning income , time off the road costs money so, in the mean time and until you can find a down load for the faults, maybe you should take it to a service dealer and have it fixed
possible even to get a copy of the codes from the technician
Diesel Toys | Answered on Jul 20, 2016
If your machine is truly spraying fuel oil out of the dipstick tube, you most likely have some severe engine damage, most likely originating from a leaky (dripping) fuel injector/nozzle. The fact that fuel oil is present in the crankcase leads me to believe that at least one cylinder has been overfueling, causing wash-down of the cylinder walls and resultant piston ring and cylinder wall (or liner) damage. Enough raw fuel is getting (first) into the cylinder and (second) into the crankcase to wash the normal oil film off the cylinder walls, resulting in excessive ring and cylinder wear. In all likelihood, you now have excessive crankcase pressure due to the damaged rings and cylinder walls, as compression pressure is being lost into the crankcase..
Have this engine evaluated by a professional, as a tear-down and rebuild is very likely necessary. At the very least, the fuel system -- injectors/nozzles specifically -- must be investigated and repaired...
Diesel Toys | Answered on May 05, 2016
my 135 fuel supply pump was leaking into the engine . I removed the pump pressured a line with air and found the leak at the seal
Diesel Toys | Answered on Feb 06, 2016
Hi Bill:
Here's a trick you might try. It should work if the broken part is not physically attached and if it is magnetic.
Find a short piece of plastic tube, even a drinking straw will do, that will slide into the hole.
Find a common nail that will just slide into the tube. Grind the pointed end off the nail so it is flat.
Slide the plastic tube over the nail also that it bumps into the head, then cut the tube off flush with the flat end.
Slide the tube with the nail in it into the hole in the end of the crankshaft.
Take your handy super magnet and touch it to the head of the nail.
If you are lucky, if you gently pull the nail/tube out with the magnet attached, the broken but will come out.
Hope this helps.
Diesel Jlg Aerial Work Platform S2 Liftlux Diesel Scissor Logo
Popular Tags
5 questions posted
Top Diesel Toys Experts
john h
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Diesel Toy Expert? Answer questions, earn points and help others
View Most Popular
Diesel Toys
  • Diesel Toys
Most Popular Question
perkins engine
  • Toys
