20 Most Recent Canon imageRUNNER 3570 Copier Questions & Answers
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Canon... | Answered on Feb 12, 2019
The problem with this code is in the fuser area. I don't have the specific manual for this model, but here's some information from a Canon IR3250 manual: III . Troubleshooting Malfunctions A. Error Codes 1. E000/E003 Thermistor 1) Is the thermistor soiled? YES: Clean the thermistor. Is the thermistor in even contact with the fixing upper roller? NO: Mount the thermistor correctly. Turn off the power switch, and remove the fixing assembly. Measure the resistance between connectors J50B-2 (FSRTH) and J50B- 3 (GNDTH) on the fixing assembly side. Is it between 120k and 290k W? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Main heater 2) With the fixing assembly removed, is there electrical continuity between connectors J50-3 (FSRN1) and J50-5 (FSRL1) on the fixing assembly side? NO: Replace the main heater. Sub heater 3) With the fixing assembly removed, is there electrical continuity between connectors J50-4 (FSRN2) and J50-5 (FSRL2) on the fixing assembly side? NO: Replace the sub heater. Thermal switch, DC controller PCB 4) Remove the fixing assembly, and detach the wiring cover. Is there electrical continuity between the terminals of the thermal switch? NO: Replace the thermal switch. YES: Replace the DC controller PCB. CHAPTER 4 TROUBLESHOOTING COPYRIGHT © 2000 CANON INC. CANON iR3250 REV.0 JUNE 2000 PRINTED IN JAPAN (IMPRIME AU JAPON) 4-43 2. E001 Thermistor 1) Turn off the power switch, and remove the fixing assembly. Then, measure the resistance between connectors J50B-2 (FSRTH) and J50B-3 (GNDTH) of the fixing assembly side. Is the resistance 1k W or less? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 3. E009 Fixing assembly 1) Is the fixing assembly rated at a voltage different from that of the power supply? YES: Replace the fixing assembly so that its voltage matches the fixing assembly. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 4. E010/E011 Connector 1) Is connector J12 of the main motor and connector J218 on the DC controller PCB connected correctly? YES: Connect them correctly. CHAPTER
Canon... | Answered on Jul 29, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Canon... | Answered on Jun 04, 2015
check the paper size in the drawer
Canon... | Answered on Aug 15, 2014
you have to do it in service mode.
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit copier...
function
panel
touch check
this will put + on the screen touch the + in the 9 possitions it pots up in and then hit reset twice. if this doesnt align it you have to replace the screen.
Canon... | Answered on Apr 01, 2014
Repost in the proper section
This is automotive questions
Canon... | Answered on Aug 31, 2013
check the DP unit connector . it is linked to DP
Canon... | Answered on Jul 10, 2011
If your looking for the meter (ie counter) there is a hard button on the display board the says counter. If your asking about duty cycle for this model copier it will be in the range of 10 to 20K. This machines are rated lower than printers. Although the print engine it self could stand to do 200k like a printer it stands to reason no-one will stand long enough to wait for that many copies on a 35ppm machine:) Hope this is helpful.
Canon... | Answered on Jun 29, 2011
try to download a different software for PCL5/PCL6
Canon... | Answered on May 26, 2011
the solution to problem is for you to change the catridge ecause the old catridge seems to have expired. thanks
Canon... | Answered on May 10, 2011
Hello joy,
I have worked on copiers for 23 years, primarily Canon. I personally think its a great little copier. As with all models of copiers it has a quirk or two. The document feeder needs a few adjustments to minimize multi sheet feeding. But all things considered, when I get a service call on a an IR "70" series copier I feel no stress. Very dependable. The IR 70 series is feature rich out of the box and may be "expanded" in many ways. Lord I sound like a salesturd. But anyway that's just one opinion. Good day to you ! :-) SPINAL
Canon... | Answered on Apr 02, 2011
Hello arslandan463,
This code means ther is a mismatch between the The size of the SDRAM memory and the main controller board This can be caused by many things, and I mean everthing from just casual usage (normal failure) or trying to modify a device to accept more or less memory or capability than it it is capable of. For example, if you added features, but did not add memory. Or if extra memory is on the copier that was needed for extra stuff is on the copier, but the extra stuff is missing.This is more complex a problem than you usually run into. I wish I could help you more, but perhaps what I have said makes sense to you as I don't know the history of your device. Canon copiers don't like to have their configurations changed without "PERFECTLY PERFORMED" functions being executed. Let me know if I jogged your memory. [email protected]
Canon... | Answered on Mar 15, 2011
The waste toner is located on the front of the machine. You first want to lower the cover that allows you to insert the toner, then locate two rather large, silver screws that connect that front cover assembly to the copier. After removing the two screws, the toner bottle will be exposed.
If you need any further assistance, please let me know.
David R.
Canon... | Answered on Dec 11, 2010
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Canon... | Answered on Dec 04, 2010
Canon imageRUNNER 3570 Copier Logo
52 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
remove error code
  • Office Equipment & Supplies
