20 Most Recent Altusen Aten CS62U-2 Port USB KVM Switch Questions & Answers
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Altusen Aten... | Answered on May 12, 2015
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Altusen Aten... | Answered on Mar 27, 2013
Reading a manual would be more useful, and if not please find out how to do configure the hot keys of a kvm switch at kvmstuff.com.
Altusen Aten... | Answered on Jan 27, 2011
It very well could be just a cable causing this problem, try switching around the cables to see if you can isolate the issue. It could be the KVM is not compatible with your monitors refresh rate though, I have seen this happen a good number of times. It will work but will blink randomly to allow the monitor to re-sync with the video card.. . I have a monitor currently on a kvm that does this exact thing. You may want to try another KVM if you can't get it narrowed down to certain cables.. there is a chance the actual KVM is causing this issue, but is not defective, it is just at a different frequency then the monitor.
Thanks so much
Tim
Altusen Aten... | Answered on Nov 05, 2010
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Altusen Aten... | Answered on Apr 23, 2010
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, try tapping scroll-lock twice to switch. It's much better than trying to use the num-lock + and - keys, since it's only a two-way KVM. Tapping Num-lock twice automatically switches, so you don't have to hit multiple buttons.
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
here is the link to the aten website.
go to the select quick guide section and locate the model # in there,
p.s. its cs not c5
Altusen Aten... | Answered on Aug 16, 2009
Are you sure, the usb cable belonging to the keyboard is plugged in the appropriate slot?
I have a wireless keyboard/mouse, so I have only 1 usb cable going into the switch. The first time, is plugged it into the slot of the mouse, and the switch did not work, so I plugged the cable in the other slot, and now everything works properly.
Altusen Aten... | Answered on Jul 28, 2009
That is the way it is designed, only the light of the PC you are controlling will be lit. Once you switch using the hotkeys, the light switches as well.
Altusen Aten... | Answered on May 12, 2009
?? ??s? ????? ???????? ??s ??? 15000 ??????s... ??? ? ??? ??s s????? ?????? ???? ???? ??????? ?? ???? ??? 3-4 ????s/??? ???? ? ??? ???? ???s ?????? ? ??s??????? ???? ??? ???????? ??? ???? ???? ?? ??? ?? 95-300 ????s ????? ????........ ??? ?? ????s??? just openthe connection and go hometab or home profit system.
here?????????http://www.bayusd11.com
Computers &... | Answered 41 minutes ago
sorry but i have no clue as to what you have , have you never heard of pen and paper to write it down
Computers &... | Answered 44 minutes ago
Gudevening po ask q lng kung panu ko mareset password q sa eregistered nklmutan at yung cp # na gnmit q dun wla ndin tnc
Computers &... | Answered 1 hour ago
Not unusual, my laptop runs very slowly during updates and very often momentarily freezes during the installation process. Best idea is to leave the computer and do something else...
Computers &... | Answered 3 hours ago
Please visit for tech support https://microsoftliveassist.com/windows-update-error-code-8007002-on-windows-8-1/
You can apply online.
Please click on this link to apply online: http://india.visahq.com/requirements/Canada/resident-United_States/
Computers &... | Answered 5 hours ago
Computers & Internet Logo
22 questions posted
Top Altusen Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Altusen Computers & Internet
Most Popular Question
switch
  • Computers & Internet
