20 Most Recent
iRiver iMP-450 SlimX Personal CD Player Questions & Answers
Can't switch on
hi
try this:
take a small flat (watchmaker) screwdriver
open the battries cartige an look for the springs that connect and holds the battries
shive the screwdriver between the last coil of the spring and extend it (for better connection)
check with brand new battries
look inside the inlet ac adapter and look for a little silver tab
shove the screwdriver inside and make some distance from its position (for better connectin)
check with the ac adapter
if that didnt worked then
check the play button - maybe it got bad connection
open the cd player
look at the play button - there is rubber between the button and the board
clean the connection with borad with some alcohol
assemble it all toghter and see if good
NO??
sounds like one of those "ghost in the machine" thing
GOOD LUCK
My iRiver e200 does hang...and it displays "USB busy.. Do not Disconnect if I connect it to PC. And I cannot play my MP3s
Hi there! Well it sounds like the flash memory in your device has failed. This may not be the case. There is no way to say without testing and diagnostics, however if you can not access the files saved to the memory via the device(Playing the files) and the computer can not access that memory when connected, there is a strong possibility that your memory has failed. I am not sure the age of the device but it is well documented that all flash memory will at some point fail because it can only be read and re/written X amount of times(this is normal). Typically most devices will reach "EOL"(End Of Life), or end of use before the memory fails. The likely hood of recovering the files located within the inaccessible memory is very unlikely but may be possible. Replacing the memory chip in the device is possible but not feasible. I hope I have been able to help you today. Please if I misunderstood your question let me know so I can get you the appropriate help. Thank's Mr.Mike
