20 Most Recent iRiver PMP-140 Digital Media Player Questions & Answers
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
iRiver PMP-140... | Answered on Jul 11, 2014
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
iRiver PMP-140... | Answered on Apr 29, 2013
Have a look about on the support website>
http://www.iriverinc.com/support/
iRiver PMP-140... | Answered on Jul 02, 2009
Here is the fix: Boot Failure
Sometimes just downloading and following the procedure in Boot Failure does not work, because the system files cannot be overwritten, in this case follow the additional instructions here to delete manually the system files.
iRiver PMP-140... | Answered on Nov 17, 2008
Try pressing the reset button that is located at the bottom of the player near the hold switch.
You might need to change your format from NTS something to FAT32. Hook up your iriver to the comp. and right click the iriver drive..scroll down to format and click the arrow to chang it. My brother told me how but i still haven't tried it yet b/c he said that i needed a older comp. to do it. but i believe it'll work once i have the option to choose FAT32.
iRiver PMP-140... | Answered on Oct 07, 2008
Hi there! Well it sounds like the flash memory in your device has failed. This may not be the case. There is no way to say without testing and diagnostics, however if you can not access the files saved to the memory via the device(Playing the files) and the computer can not access that memory when connected, there is a strong possibility that your memory has failed. I am not sure the age of the device but it is well documented that all flash memory will at some point fail because it can only be read and re/written X amount of times(this is normal). Typically most devices will reach "EOL"(End Of Life), or end of use before the memory fails. The likely hood of recovering the files located within the inaccessible memory is very unlikely but may be possible. Replacing the memory chip in the device is possible but not feasible. I hope I have been able to help you today. Please if I misunderstood your question let me know so I can get you the appropriate help. Thank's Mr.Mike
iRiver Audio... | Answered on May 20, 2020
Hi!
Please check the list of manuals to iRiver mp3/mp4 players. Hope you can find the one to your device and solve the problem! https://manualsbrain.com/en/brands/iriver/mp3-slash-mp4-players
iRiver Audio... | Answered on Nov 16, 2018
Apparently it is not compatible with newer versions of Windows, but there may be a workaround solution. Which version of Windows are you trying to install a driver for?
iRiver Audio... | Answered on Oct 19, 2018
iRiver PMP-140 Digital Media Player Logo
Popular Tags
21 questions posted
Top iRiver Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • iRiver Audio Players & Recorders
Most Popular Question
iriver pmp 140 boot failure message
  • Audio Players & Recorders
