20 Most Recent Canon P23-DHV Calculator Questions & Answers
Enter a number, then press + for positive, or - for negative.
Example,
47 +
12-
___
35
It is bass-ackward from most calculators, and you will screw up with any other calculator when you get used to it.
Just remember what value the number is that you just put in (i.e. positive or negative.)
Canon P23-DHV... | Answered on Dec 21, 2018
SOLUTION: I was just having this problem with mines but I was able to fix it. The I don't much about any memory overload or anything (I only do simple add and subtract computations). First I removed the cover and removed the paper from the feed (its a pain I know to reload but you want you're calculater fixed right?). Next I removed the ink roller (it's marked 'PULL UP'). Then after some tinkering, nudged the numerical stamp to the left 2-3 times which immediately started the feed right up. My explanation is that the printer had gotten jammed/off track causing the FEED to stop working. You'll know it definitely if you hear a low quick hum each time you switch to the print function which is probably the little motor saying 'hey, umm I would print if I was connected to a printer!'. Happy Calculating!
Canon P23-DHV... | Answered on Jan 09, 2018
Ash fault? I think you mean "asphalt" but that's OK. You haven't given enough information to solve the problem, but here's what you need to do.
You know the area of the roof is 300 square feet (sq ft). You should know the area of each asphalt shingle, although that's the information you didn't give. When you know that figure, the calculation is very simple:
number of shingles needed = area of roof / area of one shingle
I don't know if this is a class problem, or if you really have a roofing job. Don't forget that on a real roof, the shingles overlap. If you do the calculation, the number you get is right only if you lay the shingles edge-to-edge. A real-world roof would need probably twice that number. Shingles come packed in bundles, and they usually tell you the area they cover. (By the way, 100 square feet is termed a "square".)
Canon P23-DHV... | Answered on Nov 24, 2016
Lorena, Staples will have it in stock, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Calculator Plain Paper 2 25 150 Pack of 3 Calculator And Cash...
Canon 1904B001AA P23 DH Printing Calculator Staples
How to Load Paper Into Canon P23 DH eHow
Canon P23-DHV... | Answered on Mar 05, 2016
It does not have a ribbon, it has inked felt rollers, It clips out of the
top of the machine.
https://www.google.com/search?q=Canon+P23-DH+V&rlz=1C1VFKB_enUS661US661&oq=Canon+P23-DH+V&aqs=chrome..69i57j69i60&sourceid=chrome&es_sm=122&ie=UTF-8#q=Canon+P23-DH+V+ink
Canon P23-DHV... | Answered on Feb 02, 2016
Hey.You probably need to change the cells ,which are on the back of your calculator
Canon P23-DHV... | Answered on Jan 06, 2016
Hi Carol,
There are switches at the top just under the screen called the "Rounding Switch" and the "Decimal Point Selector Switch".
With the rounding switch you can select rounding up or down, but you may also want to use the second switch to show more digits after the decimal. Put it in the "F" position to show all decimal places. When it is in the 0, 1, 2 positions, it strips off and round the numbers.
Here is the link to the manual as well, look at the section detailing the "Decimal Point Selector Switch".
(You will need an Adobe Acrobat Reader to look at the manual.)
Hope this will help you. http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
Canon P23-DHV... | Answered on Nov 15, 2014
Canon P23-DHV Calculator Logo
273 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
order tape printing
  • Office Equipment & Supplies
