20 Most Recent Canon CP1250-D Calculator Questions & Answers
Canon Printer Not Responding is a common error that you might get. This error can be displayed because of several reasons like Outdated drivers, weaken network connections, USB problems, and much more. For resolving this error, you have to follow the troubleshooting steps mentioned below. These are the basic procedures that will help you to resolve the error successfully. Methods to Troubleshoot Canon Printer Not Responding: Run the Printer Troubleshooter to Fix Canon Printer No Response Error: The windows have a built-in printer troubleshooter that can fix your error. This tool will help you out to fix the issue of the printer not responding: Press the "window logo key" and type "troubleshoot". Then select Troubleshoot or Troubleshooting. In troubleshooter, click Printer and then "Run the troubleshooter" (using windows 10) Click "Use a Printer" (using windows 7) Follow the following instructions to complete the troubleshooting. If this works for you then you don't have to go on further methods. Restart the Printer Spooler Service: The printer spooler service on your computer manages your communication between your printer and computer and print jobs. If this service is not working properly on the computer then your canon printer will stop responding. You have to reset this service to fix your printer issue. Press the "window logo key" and R simultaneously on your keyboard to request the Run. In the Run type "service. MSC" and press Enter. Click "Print Spooler and then click Restart. Check that your printer is printing the document. For More Follow this:- Canon Printer Not Responding
Canon Office... • Answered Yesterday
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Canon Office... • Answered 3 days ago
try searching this website since this question comes up at least twice a week !!
Canon Office... • Answered on May 12, 2021
It would be helpfulful if your query listed the OS of the computer connected to the printer as failure to do so makes a respondant have to address multiple solutions. The solution common to both Windows and Mac computers generally involves removal of the printer from listings as a device attached to the computer followed by reinstallation of the printer. With the Apple computers:
  1. Click the Apple icon in the top left of the screen.
  2. Click System Preferences.
  3. Click Print & Fax.
  4. If the padlock in the bottom left is locked: Click it, enter your password and click OK.
  5. Click the - button. to remove the printer and the + to add it again leaving the options on default.
These common procedures are listed on: https://www.fixkb.com/2009/02/mac-canon-printer-error-306_1485.html Basically, after removing the printer programmatically and detaching it from the computer, reattach it and follow the installation dialogue boxes. If there is a glitch (failure to install), try installing the drivers manually. If the OS is Windows then remove the printer using the printers and scanners menu, then just follow the add printer dialogues. As with the Mac's, if installation fails, try installing the drivers manually. The 306 error refers to a "communications" error between computer and printer.
Canon Office... • Answered on May 10, 2021
This error code is a diffuse code meaning that there was a temperature rise failure detected in the fuser unit. The best solution is to call a local Canon authorized repair facility and have them send a technician to service the unit. I provide links to several videos which show how involved the process is to clear the error. https://www.youtube.com/watch?v=OXnRGhBvV08 https://www.youtube.com/watch?v=ABDciNqOUkA https://www.youtube.com/watch?v=kT6AOPiEMGE
Canon Office... • Answered on May 09, 2021
Replace ink! Support Code = 1688 The ink has run out. Replace the ink cartridge and close the paper output cover. If printing is in progress and you want to continue printing, press the machine's Stop button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Dec. 26, 2012
A Support Code and A Message Are Displayed
Canon Office... • Answered on May 06, 2021
The easiest fix for this error is to perform a power cycle. Doing so will flush out any broken configuration and forces the printer to add a new configuration. Here is how to do it.
Unplug your Printers power cord as well as the USB cable that is connected to your PC.
Keep the printer powered off for at least 3 minutes. After three minutes, plug the power cord and USB cable back and turn it on.
Check for any improvements after the printer restarts. If not, continue the troubleshooting steps.
Power off the printer again.
Open the printer’s lid for the scanner. Turn on the printer again keeping the lid open.
Close the lid after the printer restarts. Check for any improvements.
Canon Office... • Answered on May 05, 2021
  1. Firstly, unplug the power and the USB cables from the printer.
  2. Open the cartridge door and press down the Power button.
  3. Continue to hold the Power button while plugging the power cord into the wall socket.
  4. Keep holding the Power button until the printer starts resetting itself.
  5. Once all the lights are on, you may release it.
  6. Wait for the green power light to turn off.
  7. Then, press and release the Power button quickly twice.
  8. The green light should blink for a few more seconds and finally stabilize.
  9. Feel free to close the cartridge door and try printing again.
The 5b00 error is often caused by ink spills on your printer in. The same applies to a full ink absorber or full waste ink counter, so reset the ink absorber.
Canon Office... • Answered on May 04, 2021
not English I do not read yours and if you do not change it most of us can not understand the question
Canon Office... • Answered on Apr 26, 2021
The code of PO2 is 5100, which means that the pen holder of printer cartridge cannot be reset normally. The most common problem occurs in the refit machine. If the supply pipe is too tight, this error will be reported, and the problem will be solved as long as the pipe is loosened inside. If there is still an error after removing the connection, it should be that the coding tape behind the pen holder is dirty, the position of the pen holder is identified with a problem, and there is a failure of the cleaning unit, which can't move the pen holder
Canon Office... • Answered on Apr 17, 2021
Canon CP1250-D Calculator Logo
Popular Tags
5 questions posted
old marine
old marine
efs_perpends
efs_perpends
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
need test canon pixma mg5220 printer
  • Office Equipment & Supplies
