20 Most Recent Loewe Aconda ACO9303 30" TV Questions & Answers
Press the power button in and TV tries to come on but fails
Common problem with this model is the line output transformer.
1/14/2014 12:08:45 AM • Loewe Aconda... • Answered on Jan 14, 2014
2answers
Loewe Aconda service manual
Prueba descargarlo de aqui:
http://www.opweb.de/manufacturer.php?manufacturer=Loewe
Suerte
7/29/2013 11:34:40 PM • Loewe Aconda... • Answered on Jul 29, 2013
3answers
Loewe Aconda 38' Owner's Manual
Have a search over this link
Manual for tv
11/20/2012 7:01:39 AM • Loewe Aconda... • Answered on Nov 20, 2012
Off and on. The set will no longer stay on or off. It switches on and off. Is it worth repairing?
The Loewe have only a few problems---this is not one of them---disconnect it and a cable or sat box if used from power for while and try again----its getting harder to find shops who will work on these at parts are scarce and expensive (remote wholesales for 85 dollars--I have 2 extra ones).Very expensive set when new but if not something easy maybe let it go......
11/4/2012 8:43:50 PM • Loewe Aconda... • Answered on Nov 04, 2012
2answers
Manual for Loewe Planus 4672Z
There is in the following site. it costs $15.99 in PDF format.
http://www.manuals-in-pdf.com/PLANUS%204672Z-p-281571.html
10/25/2012 2:02:47 PM • Loewe Aconda... • Answered on Oct 25, 2012
Loewe Aconda ACO9303 30 tv. With power button pushed red light comes then green light, hear static sound for one second as if tv were to come on. No picture with sound, red light stays on while green
My Loewe did the same thing tonight. The picture went blank and the rered and green light came on together. Any suggestions?
10/25/2012 1:54:02 AM • Loewe Aconda... • Answered on Oct 25, 2012
2answers
Tv won't turn on
yes but you have to open the tv
1/31/2012 7:59:36 AM • Loewe Aconda... • Answered on Jan 31, 2012
0answers
SCHEMA
Be the first to answer 1/5/2012 3:56:20 PM • Loewe Aconda... • Posted on Jan 05, 2012Be the first to answer
When you turn the tv on, it lights green and tries
I repaired a lot of these sets when they were new and under warranty.
The most likely reason for 'shutdown" which is what you are describing, is one of two parts.
The "Flyback" or High voltage transformer in these sets fails; usually with back off when you try to turn set on you see a little arc at top of high voltage transformer---means it is bad-----so common I have literally replaced dozens of them.
The second common (not as common as the transformer) reason is there are a number of special capacitors right around the same area as the transformer; they do not short or burn---they open like the filament in a old style light bulb----a little tricky to find but not expensive.
The Flyback transformer is black with a large red wire coming out of the top that goes into the picture tube; part may be found on internet for approx 50 dollars or Loewe parts center for 75 plus.
Everything about these sets was expensive; I still have 3 brand new remotes for them--wholesale on them about 85 dollars.
SD TECH
5/13/2011 11:33:41 PM • Loewe Aconda... • Answered on May 13, 2011
Basically, the TV simply cut out and will not
Power Supply board needs replacement or require component level repair by an expert.
Thanks
5/12/2011 10:45:01 AM • Loewe Aconda... • Answered on May 12, 2011
3answers
I'm not sure if my problem is exactly the same? I
I know a lot about these sets---I did warranty work on them when they were new and later---Set was designed in Germany and the company based in England---for a while the parts were very hard to get---but the last time I fixed one there was a Parts center here in the USA.
Set is basically modular in design--meaning if the problem cannot be traced down and found you can buy from the USA SOURCE a replacement board.
Answer a few questions and I will try to help you.
1.) Before the set failed did the picture fill the entire screen from right to left and top to bottom?
2.) When it shuts off does the power light stay green or go to red? (standby).
3.) Does the set make any unusual sound or have a burning smell?
THERE IS ONE VERY COMMON PROBLEM ON THIS SET--THERE ARE ABOUT 8 CERAMIC CAPS ON THE "MAIN" board----One of them opens (does not short!)
This cap is almost in the middle of a group of brown caps (the larger ones never fail--it is fairly small) I think I still have some new ones here--if you need I can look for them and tell you what markings id the cap you are looking for.
Someone has to unsolder each cap from the board and check them with a cap meter---if they find one open---this is the problem.
Regards, SD TECH
1/30/2011 1:44:57 AM • Loewe Aconda... • Answered on Jan 30, 2011
No picture, black screen
Hi
Does the unit power up ok or revert into standby? or are both green and red lights on, on the control button?, this tv has common problems with the power supply failing and there is a repair kit available.
regards
TechSupp12
12/11/2010 4:46:07 PM • Loewe Aconda... • Answered on Dec 11, 2010
TV turns off by itself and then cycles with the
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
12/9/2010 11:01:12 AM • Loewe Aconda... • Answered on Dec 09, 2010
0answers
When powering up all i
Hello
Your TVs video output transistor [Red] has got shorted. Usually a transistors are used in most of the colour telivisions in video output stage.. If it is a transistorised video output stage, replacing red output transistor will solve the problem. In some modern sets there are so many types of Integrated Circuts [ICs] are used. If your TV uses Ic as video output, replace the Ic.
10/17/2010 2:47:26 PM • Loewe Aconda... • Answered on Oct 17, 2010
Set went off while watching and now red and green light alternate
Hi
Thanks for using FixYa. It seems to be a horizontal/vertical circuit issue. You’ll need to open the back of the unit and check/test HOT (horizontal output transformer) and flyback, replace the part that has gone bad.
This is only recommended if you have electrical expertise.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6/28/2010 6:45:42 PM • Loewe Aconda... • Answered on Jun 28, 2010
Tv will not turn on
Ur tv power supply board is dead.Replaced the power supply board will fix this and get ur power back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
5/9/2010 9:22:30 AM • Loewe Aconda... • Answered on May 09, 2010
I have green lines across the length of the tv
Its Flyback lines caused by the G2 voltage being to high.check the voltage it should be around 520 volts
4/13/2010 7:54:26 PM • Loewe Aconda... • Answered on Apr 13, 2010
Loewe Aconda ACO9303 30" TV Logo
70 questions posted
Top Loewe Televison & Video Experts
Robert Struzinski
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Loewe Televison & Video
Most Popular Question
not sure problem exactly same
  • Televison & Video
