20 Most Recent Command ComSwitch 3500 (CS3500) Questions & Answers
The power light on My
Try to reset by pressing the reset button or press the small hole at the back of the device. If it is not working, that is the time to replace it.
12/13/2010 8:16:18 AM • Command... • Answered on Dec 13, 2010
Can't receive a fax
I used to be able to receive them automaticlly, but then I moved and when I rehooked it up I could no longer get them automatically. I can still get them but I have to be there to push the button when a fax is coming through. Help.
4/6/2009 8:31:51 PM • Command... • Answered on Apr 06, 2009
Switch will not go to voicemail
Dear Fred
plz find ur solution at following link
http://mgetty.greenie.net/doc/mgetty_16.html
12/7/2007 4:56:22 AM • Command... • Answered on Dec 07, 2007
tip
Is Remote Computer Repair Safe?
Remote Computer Repair Remote computer repair has revolutionized the way we address computer issues, offering fast and affordable solutions without the need to leave our homes. With the ability to connect remotely, qualified remote support providers like Geeks On Command can tackle a wide range of computer problems, from virus and malware removal to fixing blue screen errors and configuring wireless printers. However, a pressing question remains: "Is it safe to let someone fix my computer remotely?" The answer is both yes, and no: While remote computer repair services offer unparalleled convenience and cost-effectiveness, the industry is not without its challenges. Scams and online identity theft incidents have cast a shadow over genuine, trustworthy companies. It's essential to differentiate between reputable remote support providers and potential scams. For a deeper dive into the safety and credibility of remote computer repair, watch this video to arm yourself with the knowledge to make informed decisions.
/uploads/images/remote-computer-repair-undefined-undefined-0.jpg
on Oct 02, 2023 • Computers & Internet
Why is my hiti photo printer is not displaying on the monitor
There could be a few different reasons why your HiTi photo printer is not displaying on the monitor. Here are a few things you can try to troubleshoot the issue:
  1. Check the cables. Make sure the cables connecting the printer to the computer and monitor are securely plugged in and in good condition.
  2. Check the printer's power. Make sure the printer is turned on and receiving power.
  3. Check the printer's status. Check the printer's control panel or display for any error messages or indicators that may indicate a problem.
  4. Check the computer's settings. Make sure the printer is properly installed and configured on the computer, and that it is set as the default printer.
  5. Restart the printer and computer. Try restarting both the printer and the computer to see if this resolves the issue.
  6. Check for updates. Make sure you have the latest driver and firmware updates for the printer. You can check for updates on the manufacturer's website or through the printer's update feature.
If you have tried these things and the printer is still not displaying on the monitor, the issue may be with the printer itself. In this case, you may need to have the printer serviced or repaired by a professional. I hope this helps! Let me know if you have any other questions.
1/2/2023 12:17:35 AM • Command... • Answered on Jan 02, 2023
Dosbox help.......................?
DOSBox Commands Z:>mount c c:\Games Drive C mounted as local directory C:\Games\ Z:\>c: C:\> C:\>cd wc2 C:\wc2> C:\wc2>war.exe
  • Use the following commands:
    • ALT+ENTER = Full Screen.
    • ALT+PAUSE = Pause emulation.
    • CTRL+F1 = Show the keymapper configuration screen
    • CTRL+F4 = Update cached information about mounted drives. Useful if you changed something on a mounted drive outside of DOSBox. Also cycles through disk images mounted using IMGMOUNT.
    • CTRL+F5 = Save a screenshot (goes to capture folder).
    • CTRL+ALT+F5 = Start/Stop recording of AVI video. NOTE: You may well have some problems with this, please see Recording Video for more information.
    • CTRL+F6 = Start/Stop recording sound output to a wave file (goes to capture folder).
    • CTRL+ALT+F7 = Start/Stop recording of OPL commands.
    • CTRL+ALT+F8 = Start/Stop the recording of raw MIDI commands.
    • CTRL+F7 = Decreases frameskip
    • CTRL+F8 = Increases Frameskip
    • CTRL+F9 = Kill (close) DOSBox.
    • CTRL+F10 = Capture/Release the mouse (if you need to use the mouse within DOSBox).
    • CTRL+F11 = Slows down the game
    • CTRL+F12 = Speeds up the game
    • ALT+F12 = Unlock speed (turbo button).
    • cycles=xxxx = cpu cycles (default = auto). Try cycles=max.
    • core=auto, dynamic, normal
12/11/2022 5:22:29 PM • Command... • Answered on Dec 11, 2022
My mc1037 stuck on no command
Suggestions in the link. This is an Android Error. https://www.google.com/search?q=My+mc1037+stuck+on+no+command ..
12/6/2022 5:25:12 PM • Command... • Answered on Dec 06, 2022
My Fusion 5laltop is stuck at a blue screen and I can't boot up my laptop?
hi A blue screen error may occur if the BIOS or a device driver is out of date or is not compatible with some other hardware or software component. Try updating the BIOS and device drivers to resolve the problem.
12/2/2021 7:16:09 PM • Command... • Answered on Dec 02, 2021
No drives is showing when listdisk command is issued
LIST DISK use a space
3/2/2020 12:38:03 PM • Command... • Answered on Mar 02, 2020
What command do i write in the edit boot options screen?
It might also depend on your mobo’s brand, sometimes is F2, Del... sometimes F10 takes you to boot priority, sometimes F12 I think. Also, screen would tel you most times what to press to enter bios setup, which is where boot options are.
9/29/2019 7:08:15 PM • Command... • Answered on Sep 29, 2019
Everytime i open my command prompt my PC reboots. how can I fix it?
This is a virus activity which prevents to use command prompt on the infected machine, this virus is called PC-OFF.bat trojan which turns off or shutdown your computer when ever you try to use command prompt by any means. The infected computer restarts on opening command prompt. This PC-OFF.bat virus creates the following files
    • password_viewer.exe
    • bar311.exe
    • photo.zip.exe
    • pc-off.bat
at the following locations
    • c:\windows\bar311.exe
    • c:\windows\password_viewer.exe
    • c:\windows\photo.zip.exe
    • c:\windows\pc-off.bat
Another variant of the this virus is recognized as bar311.exe virus A.K.A. winzip123 which will have almost the same symptoms and when ever you boot your Windows Xp computer in safe mode it will say a message Thank You!!! Password:Winzip123 Let's find out the fix to remove this shutdown virus completely from computer. Fix: 1. Open Task Manager by pressing Ctrl+Shift+Esc, click the process tab and locate the process named 'password_viewer.exe' or 'bar311.exe' or 'photo.zip.exe' one by one and right click and select 'End Process' 2. Open Start Menu >> Run, type regedit and press Enter key or OK button 3. Navigate to the following path HKEY_LOCAL_MACHINE \ SOFTWARE \ MICROSOFT \ WINDOWS NT \ CURRENTVERSION \ WINLOGON 4. Locate the key named Userinit in right pane "Userinit" = C:\WINDOWS\system32\userinit.exe,bar311.exe" double click and remove the text 'bar311.exe' from the above OR "Userinit" = C:\WINDOWS\system32\userinit.exe,photo.zip.exe" double click and remove the text 'photo.zip.exe' from the above OR "Userinit" = C:\WINDOWS\system32\userinit.exe,password_viewer.exe" double click and remove the text 'password_viewer.exe' from the above Note: Please make sure after editing the above Userinit key value it should be only C:\WINDOWS\system32\userinit.exe (as shown in the image below) 5. Navigate to the following path now HKEY_CURRENT_USER \software\microsoft\windows\currentversion\explorer\advanced Change Value of the following registry Key's :- "Hidden"=dword:00000001 (1) - Change to '1' "HideFileExt"=Dword:00000000 (0) - Change to '0' "ShowSupperHidden"=Dword:00000001 (1) - Change to '1' 6. Navigate to the following registry path HKEY_CURRENT_USER \software\microsoft\Command Processor Find the registry key named autorun, right click and delete this key. The value of the key would be autorun=c:\windows\pc-off.bat 7. Open notepad and type the following commands @echo off del /a /f c:\windows\bar311.exe del /a /f c:\windows\password_viewer.exe del /a /f c:\windows\photo.zip.exe del /a /f c:\windows\pc-off.bat pause Save it as remove-pc-off-virus.bat and double click to run it. Or just download this batch file here and run it by double click. 8. Search for bar311.exe OR password_viewer.exe OR photo.zip.exe OR pc-off.bat and delete these files where ever found on your computer. 9. That's it, Enjoy the pc off virus is now completely removed from your computer.
6/9/2019 9:04:12 AM • Command... • Answered on Jun 09, 2019
No bios display, and stable display of American Megatrends. Delete, F2, F8 command doesn't work. What will I do ?
unplug everything and take out the RAM and boot see if bios come on. its possible a faulty peripheral is overloading teh power supply/motherboard
5/20/2019 3:43:37 AM • Command... • Answered on May 20, 2019
IF I INSERT A PIVOT TABLE IN A WORKSHEET THE PASTE COMMAND ARE DISABLED
problem is in software reinstall it and try again.
5/1/2019 10:28:28 AM • Command... • Answered on May 01, 2019
How do I stop a command on Alexa
Say "Alexa" and it will stop to listen to a new command
4/26/2019 9:22:42 PM • Command... • Answered on Apr 26, 2019
tip
How to find motherboard specifications in Windows 10 with CMD
Command prompt way to find motherboard specifications in win10
on Mar 18, 2019 • Computers & Internet
Hello, how do i do a factory reset with command prompt. the ususl method does not work as only optionsrepair and recovery ect are there. no reset option. dell latitudee7240 win 7. rstrui.exe. gets is
The instructions are:
  1. Turn on the computer.
  2. Press and hold the F8 key.
  3. At the Advanced Boot Options screen, choose Safe Mode with Command Prompt.
  4. Press Enter.
  5. Log in as Administrator.
  6. When Command Prompt appears, type this command: rstrui.exe.
  7. Press Enter.
  8. Follow the wizard instructions to continue with System Restore.
Restore To Factory Settings - Guide for Windows XP, Vista, 7, 8, 10..
before you try this go to this link and have a read up first. factory reset with command prompt Google Search
12/4/2018 12:04:26 PM • Command... • Answered on Dec 04, 2018
Command ComSwitch 3500 (CS3500) Logo
10 questions posted
Top Command Computers & Internet Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Command Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Command Computers & Internet
Most Popular Question
power light
