20 Most Recent
XFX GeForce 6600 GT, (128 MB) Graphic Card Questions & Answers
Hi i have Aopen computer and nvidia geforce 6600,
HELLO THERE
You may want to boot into bios and see if the video display is set to agp or pci and change it from their than save and reboot and if that does not help boot into the safe mode and uninstall the update and if needed reinstall the card,,, geforce has been having a problem with these updates and depending on your operating system it can be non compatable so, please try these solutions ok
best regards michael
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
No sound xfx one
You must set up port in drivers and in windows
analog for speakers and headset, or
digital for hdmi to tv speakers
How to repair msi vr320x with no display?
Does both the port not giving you display did you check the memories is it all fine set also the power you have connected it properly try it in different machine check the PCIE Volts which slot is suitable for your Card on your motherboard.
try the display cables and cooling all ok than i am afraid you need to send it to a workshop or you can fix if you know chip level work so there is An IC if fails or leak it does not give any out put so you need to change that.
Nvidia 9600 gt
Maybe you have set the view to large icons in properties.
