20 Most Recent JVC KD-S6060 CD Player Questions & Answers
2answers
Hello, my car stereo JVC KD-S606 is reseting every
try to use direct current from battery with a fuse in between them it would solve your problem
2/24/2015 9:28:14 AM • JVC KD-S6060 CD... • Answered on Feb 24, 2015
manual
Manual and wiring diagram needed for JVC KD-S6060
You may download a copy of the instruction manual here. The installation guide is appended to the end.
7/12/2012 4:57:30 PM • JVC KD-S6060 CD... • Answered on Jul 12, 2012
Manual tuning
Manually preset one of the stations to the iTrip. Follow the instructions beginning on page 9 of the manual.
6/3/2012 6:48:44 PM • JVC KD-S6060 CD... • Answered on Jun 03, 2012
Cant get cd out
long press the open button if its CPU's disk drive,if its DVD then contact engineers
3/28/2012 1:43:08 PM • JVC KD-S6060 CD... • Answered on Mar 28, 2012
Newly installed in a camper from the leisure
Do you have power going to both the red and yellow wires? The red wire generally goes to a switched power source and the yellow should be constant. Both wires need to have power going to them in order for the unit to work properly.
11/3/2011 7:23:25 PM • JVC KD-S6060 CD... • Answered on Nov 03, 2011
How do I set the
press the select button then scroll with the up and down button until h or m light up on screen then press vol button up and down to set or keep your finger on the sel button and adjust with left up down then press right up down to select hour or minutes
8/10/2011 12:21:15 PM • JVC KD-S6060 CD... • Answered on Aug 10, 2011
The CD does not want
try either pressing the reset switch if there is one, or disconnect power to the radio for an hour or so.
8/31/2010 5:44:45 PM • JVC KD-S6060 CD... • Answered on Aug 31, 2010
My cd won't eject. the car recently had the
Some players get set to a default like when it was fresh out of the box when power is removed. Since you radio from the factory knows there is no disc in it, it thinks there is nothing to eject. Push the reset button and your disc should eject.
6/21/2010 5:13:53 AM • JVC KD-S6060 CD... • Answered on Jun 21, 2010
The radio powers up but turns off after a few
disconnect the speaker wires at the unit and tape them off one by one. Then re-power up the unit, if it still shuts down, it is an internal problem and needs service. If it stays on, re-connect one speaker at a time and test power again. When you find the speaker with the problem it will shut off. It's going into protection and keeping itself from damage. Once you find the bad wire or speaker, check the wire by disconnecting it "at the speaker" and turning the unit back on. if it still cuts out, replace the wire. If it stays on, meter the speaker by checking it for resistance, if your meter reads 1..... the speaker is blown and needs to be replaced. If your not handy with a meter, go to any car audio shop with the speaker and they can test it for you, usually for free. Hope this helps.
6/18/2010 1:15:01 PM • JVC KD-S6060 CD... • Answered on Jun 18, 2010
Is there any way to play an mp3 player through
i use a fm transmitter in my car with this radio . what you do is connect the device to an mp3 player and it transmits the music to the radio on this cd player. its so simply really and mine cost €40 and you can get it in almost all electric stores.
3/12/2010 1:09:12 PM • JVC KD-S6060 CD... • Answered on Mar 12, 2010
My JVC KD-G331 Cd Player Won't Work In My Clio (X reg)
Hi, did you fix this problem?
I'm having exactly the same issue myself.
3/6/2010 4:24:29 PM • JVC KD-S6060 CD... • Answered on Mar 06, 2010
I need a JVC KD-S6060 car radio and CD manual
try pacparts.com
2/10/2010 5:01:26 PM • JVC KD-S6060 CD... • Answered on Feb 10, 2010
I have a corsa and am trying to fit a jvc stereo
You need to swap the red and yellow round so it dont loose its memory everytime you turn the key off, JVC normally have a fuse that can change position if you want the power on all the time. Check the handbook.
11/18/2009 11:26:00 PM • JVC KD-S6060 CD... • Answered on Nov 18, 2009
Wont save pre-set stations
you need to make sure the red wire is connected to the battery via a fuse(normally inline or in the back of the unit) and the yellow is connected to ignition live(ignition needs to be on to give power). if the red wire is not permanantly live then the pre-program function will be reset every time you turn the ignition off.
10/6/2009 6:58:16 PM • JVC KD-S6060 CD... • Answered on Oct 06, 2009
My car stereo a jvc kd-s6060 losses pre-set
Your wires are probably backwards. the yellow one is for memory and it gets wired to direct battery voltage to hold the memory. The red wire is for power when key is turned on.
10/6/2009 6:50:12 PM • JVC KD-S6060 CD... • Answered on Oct 06, 2009
JVC KD-S6060 CD Player Logo
52 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
manual wiring diagram needed jvc kd
  • Car Audio & Video
