20 Most Recent
JVC KD-G801 CD Player Questions & Answers
Just bought a brand new
Please check if the wiring was done correctly. check the ground the all time +12 volt and the swittched +12 volt. If the set does not power up then I suggest that you MUST take the warrranty claim being a new set. Refer to the dealer before you can open the player so as not to void the warranty
The memory on my new jvc car stereo model kd-s17
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Hi I have a JVC
Yes... the wire designated for constant power which powers the clock and some of the lessor memory functions is disconnected.
I would remove the radio and look for the lead that is disconnected and have a constant power lead attached to it to cure this issue.
Have the mechanic who did it the first time do it.. as it was already paid for him to do so in the first place...
I have removed my JVC KD-G801 from my car but
Hook your power wires and ground up to a cordless drill battery , 12 volt, or 14 volt. Or use jumper wires from car battery. Hit eject. You don't need all the speakers etc hooked up.
How can i turn the aux option on on my jvc kd-g801
it's not for running your ipod or whatever else, it's for steering wheel control for those cars that have the feature. that's what it says in the manual anyway, there's gotta be a way to run the ipod through though for sure
IPod to car stereo connections
well if there is alittle hole thing on the radio, you have to buy a wire addapter at walmart, then plug one end in the headphone hole and one end in the radio hole.
