20 Most Recent JVC KS-RX177 Cassette Player Questions & Answers
Send me your emailID to [email protected]. I will send you the manual.
JVC KS-RX177... | Answered on Mar 10, 2012
The only way to play an mp3 player through this head unit is through an adapter. You will need to go to Best Buy or some electronics store and buy a cd-to-cassette adapter. You just plug the adapter into the mp3 player's headphone jack and insert the cassette into the head unit. Let the cassette play and play your music through the mp3 player and boom, you have a mp3-capable head unit.
JVC KS-RX177... | Answered on Mar 05, 2011
The remote wire is usually blue. Make sure u do not use the blue for speakers. The remote wire should be in with the power wires.
JVC Car Audio &... | Answered on Jan 13, 2020
Most car harnesses will correspond by Colour thus look out for an orange Colour from the pre-installed/ pre-selected wires.
Now the issue is, not all cars come with such wires pre-selected and installed ie bunched up with the Audio cluster, for such, you need to identify the wire yourself that connects to the light switch on your dash board and tap into it.
JVC Car Audio &... | Answered on Dec 10, 2019
the accessory wire needs to work with the key turning. the battery wire connects to the battery. if you have a volt meter it can be very easy to find your wire connections in the fuse box. find the ignition fuse in the box set your meter to volts dc take your black lead to a chassis ground and the red lead to one side of the ignition fuse turn your key to accessory and see if you get 14 volts if you do get it thats your connection. if not try the other side of the fuse.
JVC Car Audio &... | Answered on Nov 28, 2019
Press the "Hour" button (or right arrow button) to set the first and second digits of the code. Release the button once the four-digit code is accurately displayed. Press the "Mode" button to lock in the code you set. Turn the stereo deck on by pressing the "Source" or "Power" button to complete the reset.
JVC Car Audio &... | Answered on Nov 05, 2019
Find and correct the problem causing it to enter protect mode.-
JVC Car Audio &... | Answered on Oct 13, 2019
Most likely, your engine might not be producing the correct amount of voltage to your stereo system. It's most likely being over worked, or even your CD player needs to be cleaned. If it's the latter, try a quick burst of air duster.
JVC Car Audio &... | Answered on Sep 26, 2019
Contact JVC directly to request.
JVC Car Audio &... | Answered on Sep 15, 2019
WHEN YOU ON A CALL YOU WILL SEE THE MIC VOLUME SETTING PUSH THE PLUS SIGN TIL VOLUME GOES
JVC Car Audio &... | Answered on Sep 12, 2019
YOU COULD TRY PLUG THE RADIO IN AND ABOUT THE YELLOW WIRE YOU PUSH A GROND WIRE INTO THE PIN HOLE AND RADIO SHOULD WORK WHEN SECURE PROPERLY
SEEM LIKE U GET DEFICTIVE HARNESS
JVC KS-RX177 Cassette Player Logo
5 questions posted
Top JVC Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
ksrx177 set radio stations like find
  • Car Audio & Video
