20 Most Recent Howard Miller Greer Chiming Quartz Wall Clock Questions & Answers
In a quartz movement clock, with a problem like this, the chime box (or whole movement) will need to be replaced. Timesavers.con carries a large selection of chiming quarts movements.
Howard Miller... | Answered on Mar 02, 2014
Clock oil, and a very small drop on each bushing, and pivot not on the gears in between the plates. Do not get oil on the hair spring if it has a balance wheel escapement. After oiling it's good to wiggle each gear back and forth to work the oil in. Good Luck in your adventure.
Howard Miller... | Answered on Jul 15, 2016
Request instructions directly from Miomare.
Home | Answered 4 hours ago
Breville is no longer viable.
Try a simple solution first. Spray the key hole and the door mechanism with a good amount of light spray oil. Then operate the key and locking mechanism 10 to 15 times to spread the oil around the parts inside. This should act as a lubricant and an light antifreeze.
Home | Answered 3 days ago
winter jasmine
Home | Answered on Oct 23, 2020
Sorry, this is not a buy and sell website. It is for advice on how to repair stuff.
Do you know if it is just suction cupped wherever you have this handle? If so try getting the thinnest spatula you have pancake Turner whatever people call them put a little bit of oil on the end of it see if you can't get underneath it and pop it loose I figure if it is the suction cup ones you might be in luck if my tip don't help I hope one will for you hell if I knew you I'd come over and fix it straight away for you
Home | Answered on Oct 11, 2020
No owners manuals. they quit making that tub over 6 years ago.
What do you need to know about it?
US Parts Center
Home | Answered on Oct 05, 2020
Push the button in the middle of the connector. After you hear a click, pull the plug with force away from the connector while holding firm with the connector.
Home | Answered on Oct 02, 2020
I pressed ******* the time button and hit the minute button as you suggested. It worked!!!! Thank you! I have an old clock that belonged to my dad from a very, very long time ago.
Home | Answered on Sep 19, 2020
Had the same problem. I took out back-up battery out and unplugged clock. Waited one minute plugged back in. All was back to normal. Put battery back in.
Home | Answered on Sep 09, 2020
Hi....did you ever find and answer to this? mine is doing the same thing? I need help--wondering what you did to fix. thank!
Home | Answered on Aug 31, 2020
Howard Miller Greer Chiming Quartz Wall Clock Logo
1 questions posted
Top Howard Miller Home Experts
john h
Tom Chichester
Are you a Howard Miller Home Expert? Answer questions, earn points and help others
View Most Popular
Howard Miller Home
  • Howard Miller Home
Most Popular Question
clock chimes correct amount chimes all
  • Home
