20 Most Recent Hit Thomas the Train Misty Island Deluxe Set Questions & Answers
This will help you out.
http://service.mattel.com/us/product_detail.asp?id=R9634&Ntt=R9634&Pn=1&Brand=Fisher-Price+Friends&Cat=Thomas+The+Train+TrackMaster
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Hit Thomas the... | Answered on Mar 31, 2014
I had the same issue. It took some DEEP GOOGLING, but I was finally able to find the manual online. Mattel/Fisher Price doesn't exactly make it easy to find, but here it is... http://service.mattel.com/instruction_sheets/T6910-0920_E.pdf
Hit Thomas the... | Answered on Jan 15, 2012
I wasn't able to find out online, but you might learn how by contacting the manufacturer:
  • Call 1-800-747-8697 in the U.S., seven days a week, 7 a.m. - 10 p.m., Central Time. Holiday hours may vary.
  • Write us at Fisher-Price Store, P.O. Box 620978, Middleton, WI 53562-0978.
  • All comments become the full and sole property of Fisher-Price.
  • For catalog questions, e-mail us at [email protected].
Good luck, and I hope this helps!
Hit Thomas the... | Answered on Jun 30, 2011
the tracks with letters are misty island put c and d together for corners (swap other side) then rickty bridge inbetween on one side and switch track on other. For numbers pretty much you can go by number (start with 1 and go left) I had to fidget a little but it worked
Hit Thomas the... | Answered on Apr 19, 2011
You could try vtechkids.com
Hit Toys | Answered on Sep 22, 2009
Did you check the metal pin and spring terminals the batteries sit between? If a battery powered toy is stored with the batteries still in the terminals can corrode and block the electrical current from the batteries. Try cleaning the terminals with a cotton bud and Very Fine sand paper. A cardboard nail file works well for this.
Toys | Answered on Dec 01, 2020
how long are your arms??
Toys | Answered on Nov 30, 2020
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Toys | Answered on Nov 28, 2020
Disconnect the electrical connector that joins the arches. Unscrew the half of the arch that holds the batteries. Check the red lead from the battery compartment. Mine had two problems - it was almost disconnected from the battery, and had another disconnect in the middle. Twist the wires together at both fault points and tape (electrical tape) or solder. I soldered and my Learning Home is now working perfectly.
--gdipersio
Toys | Answered on Nov 16, 2020
There are tutorials and video's on YouTube and on Goggle then on how to make your own decorations for birthdays and for Christmas and Easter and Halloween and for Valentines day too.
Toys | Answered on Nov 11, 2020
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Toys | Answered on Oct 04, 2020
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Toys | Answered on Sep 29, 2020
Maybe you can search on Amazon or Ebay. This manual is cetainly on sale.
Toys | Answered on Aug 28, 2020
Hit Thomas the Train Misty Island Deluxe Set Logo
16 questions posted
Top Hit Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Hit Toy Expert? Answer questions, earn points and help others
View Most Popular
Hit Toys
  • Hit Toys
Most Popular Question
need manual thomas
  • Toys
