20 Most Recent JVC KD-S680 CD Player Questions & Answers
manual
Not reading cds
first ask your self
has it ever worked?
are these cds burt as mp3 cds and not just plain audio cds?
it might need to have the lense on the laser cleaned other than that its pointless and probably is just bad, the cd player is old
7/16/2010 2:30:15 PM • JVC KD-S680 CD... • Answered on Jul 16, 2010
Can I run positive lead from the battery to the
yes but that is not a good place to tap in, the ignition switch or fuse box is a better choice.
2/17/2010 1:43:23 AM • JVC KD-S680 CD... • Answered on Feb 17, 2010
My radio will not turn on at all. It will light up
Sounds like an internal circuit board problem. Usually costs more to fix than a new deck
1/7/2010 4:13:55 AM • JVC KD-S680 CD... • Answered on Jan 07, 2010
Cannot set clock on kd-s680
Press and hold SEL for more than 2 seconds. SCM link , CLOCK M , or CLOCK H will appear . "THATS WHAT WAS BUGGIN THE HELL OUT ME "SCM link" ok when you see that on the right press up or down on the ssm button to change it to Clock H and Clock M . Then just adjust the hour and minute with the turn knob that surrounds the SEL button . After set press the SEL button to finish the setting. Have nice day :)
6/3/2009 11:23:29 PM • JVC KD-S680 CD... • Answered on Jun 03, 2009
I don't know which JVC unit I have.
no i dont think so. but it is fairly easy to remove if u visit your nearest store that sell car stereos ask them for the removal too for a jvc radio. they should give u to flat L shaped pieces of metal all u have to do is remove the thin plastic trim piece around the radio then on both sides of the radio between the radio and the metal cage that holds the radio they will slide in u may have to play around with them a little till they unlock the radio but when they do all u have to do is just slide the radio to u enough to read a white label on the top of the radio that will give u the model number. should take no longer than 15 min. after that pull the tools out then just slide it back in till u here or feel it lock and your done oh dont forget to put the radio trim back on.
11/17/2008 1:15:02 PM • JVC KD-S680 CD... • Answered on Nov 17, 2008
2answers
Car cd changer not working!
try pulling the fuse and resetting it, make shure its the +12v cont wire
Don
7/20/2008 7:38:55 PM • JVC KD-S680 CD... • Answered on Jul 20, 2008
2answers
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
6/18/2008 11:40:39 AM • JVC KD-S680 CD... • Answered on Jun 18, 2008
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
6/18/2008 11:31:59 AM • JVC KD-S680 CD... • Answered on Jun 18, 2008
2answers
2001 Mustang 6-disk CD player
does it give an error code? usually it just a gear timing problem, will it load discs that are in it?
1/25/2008 6:49:37 PM • JVC KD-S680 CD... • Answered on Jan 25, 2008
Wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
1/2/2008 7:28:16 PM • JVC KD-S680 CD... • Answered on Jan 02, 2008
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
3/15/2007 1:21:34 AM • JVC KD-S680 CD... • Answered on Mar 15, 2007
JVC KS-A102 amplifier. Diagram for it please.
Question edited for clarity and toss in CAPS. Service Manual here. click Download https://www.eserviceinfo.com/pdfview.php?fileid=253767 ..
5/8/2024 3:41:54 AM • JVC Car Audio &... • Answered on May 08, 2024
JVC KS 102 car amplifier. Wiring diagram for it please?
Question edited for clarity. Turn question around, add magic word. https://www.google.com/search?q=JVC+KS+102+car+amplifier.+Wiring+diagram ..
5/5/2024 8:11:21 AM • JVC Car Audio &... • Answered on May 05, 2024
JVC In-Dash CD Receiver - KD-G140. Wiring diagram for kd g 140 JVC please?
Question edited for full 'make model (what it is)'. Installation and User Manual. Wiring diagram is on Page 4. https://www.manualslib.com/manual/81350/Jvc-Kd-G140.html#manual ..
3/31/2024 6:54:49 PM • JVC Car Audio &... • Answered on Mar 31, 2024
JVC KW-V940BW Car Play, Android Audio, Bluetooth and USB stopped working
See page 77 troubleshooting of user manual for help B5A-2488-00_KWV_M_EN.pdf (jvckenwood.com)
2/14/2024 2:14:33 PM • JVC Car Audio &... • Answered on Feb 14, 2024
My JVC KW-XR610 comes on then shuts off just started
See page 4 of manual (Troubleshooting) Install_KW-XR610[J]f.indd (jvc.com)
1/7/2024 10:38:28 AM • JVC Car Audio &... • Answered on Jan 07, 2024
JVC KD-S680 CD Player Logo
Popular Tags
16 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
run positive lead from battery
  • Car Audio & Video
