20 Most Recent LeapFrog My Pal Violet Questions & Answers
Here you are. It took a while to find the instructions!
In addition, if you would like to delete the data on your device prior to recycling, open the LeapFrog Connect program, sync your device via USB to your computer, click on the product you would like to reset from the "My Products" screen, then under "Settings," select "Reset". If you have not downloaded LeapFrog Connect, please follow these instructions to do so.
eWaste
LeapFrog My Pal... | Answered on Jan 19, 2016
One thing to check, especially if you are replacing batteries, is for corrosion on the terminals. I just replaced batteries in my daughter's Violet, and it wasn't working. When I looked closer, I found a couple of the terminal contacts had corrosion (looks like rust). I took a few Q-Tips with some white vinegar to clean them up until I could see metal on the contacts again. After putting the batteries back in, it worked fine.
LeapFrog My Pal... | Answered on Jan 27, 2015
I put in a new set of batteries and the data synced/downloaded to scout.
LeapFrog My Pal... | Answered on Jun 21, 2014
My experience is that after charging for some tens of minutes it will start. But I seem to be unable to charge the battery enough to have it work for long.
LeapFrog My Pal... | Answered on May 21, 2014
Our violet was doing the same thing, as though the on/off paw was pressing all the time. I have just replaced the batteries, and it seems to have fixed it. In one of the manuals I read it says if she is behaving erratically, then replace the batteries, and that the included batteries are for display only. We only had her a month!
LeapFrog My Pal... | Answered on Jan 05, 2014
LeapFrog My Pal Violet Logo
46 questions posted
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
Crystal Walters
Crystal Walters
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
View Most Popular
LeapFrog Toys
  • LeapFrog Toys
Most Popular Question
violet stop barking
  • Toys
