20 Most Recent Casio W94HF-3AV Wrist Watch Questions & Answers
I used the online CASIO web site to locate the appropriate manual and followed directions. Use the bottom left (C) button of the watch to keep pressing between the various modes until I was in the ALARM Mode. Then PRESS the upper right (B) button to toggle the DAILY ALARM and HOURLY CHIME to "OFF", "DAILY", "HOURLY" and "BOTH" on/off.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1950.pdf
http://support.casio.com/manual.php?rgn=1&cid=002
Casio W94HF-3AV... | Answered on Sep 11, 2012
i have got casio illuminator,i dono how to stop alarms,there is no way to stop alrams?
Casio W94HF-3AV... | Answered on Nov 29, 2010
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Casio W94HF-3AV... | Answered on Oct 25, 2010
browse through my tips and you will find link for all Casio watch manual downloads.
Casio W94HF-3AV... | Answered on Oct 01, 2010
usually when the watch still works but you cannot make or change any settings and you do not see any reaction or change when you push a button, then it means that one of the buttons is stuck (as if permanently pushed) and the watch will not react to any button until the stuck button is released. Inside the watch there are metal fingers (contact blades) that the buttons actually push, and sometimes one of these finger blades can get stuck even though the button has returned outward. try (with tweasers) to pull on each button to see if it will move outward and allow the watch to start functioning again. If not, then the watch must be opened,and with a fine pin-like probe, each metal finger blade must be tested for proper movement and position. Also, when a battery is replaced, occasionally the housing is not seated correctly when the "movement" is replaced in the housing (if it was removed in the first place), when the cover is back in place, if there is a plastic or metal bezel ring, maybe the ring is not seated correctly. goodluck, Macgivor
Casio W94HF-3AV... | Answered on Jan 27, 2010
while battery on its place touch the 1 End with battery and secound with AC small Gold dot
from
AmFix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Casio W94HF-3AV... | Answered on Sep 14, 2009
you have lost the alarm spring or put it in wrong spot. it touches the alarmplate in the case back. in some models if the back is upside down same problem.
Casio W94HF-3AV... | Answered on Apr 28, 2009
Springs? No springs in a solar powered electronic watch. If there is anything wrong with it, return it to Casio for repair.
https://www.google.com/search?q=Casio+WVA-430TU+Wave+Ceptor
Casio Watches | Answered on May 02, 2020
Go to the Casio website here:
http://world.casio.com/wat/download/en/manual/
Enter the 4 digit code that is on the back of your watch, and the instructions will appear.
Casio Watches | Answered on Apr 01, 2020
On the case back usually or user manual
Casio Watches | Answered on Dec 16, 2019
C`mon download manual for make and model of watch as a pdf and read
Casio Watches | Answered on Nov 02, 2019
Casio W94HF-3AV Wrist Watch Logo
14 questions posted
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
casio illuminator w 94h
  • Watches
