20 Most Recent ULINE U-Line 1175BEVS-00 1000 Series 24" Reversible Door Beverage Center Refrigerator with Dual Cooling Zones in Stainless Steel 1175BEVS-00 Questions & Answers
I am not familiar with this unit but in guessing but I would not assume the thermistor is bad, actually if as you say the compressor is running that is all the thermistor can do. My first guess is the condenser needs cleaning, that is the area where it gets warm. If that is clean then the possibility of a refrigerant leak is there. If not that then the compressor most likely has a bad valve in it. I would suggest contacting a refrigeration tech after everything has been cleaned and it still does not cool.
ULINE U-Line... | Answered on Dec 19, 2014
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
Refrigerators | Answered 17 hours ago
Yes they do
https://www.youtube.com/watch?v=dumnITQZHXI
Refrigerators | Answered 3 days ago
call the local repair service no doubt it needs professional help in person not thru a computer
Refrigerators | Answered on Sep 24, 2020
Sounds like either you have a defective fan motor or it is not getting the proper voltage.
Refrigerators | Answered on Sep 20, 2020
Yes it does exist. It is a Recreational Vehicle refrigerator.
Service Manual Model 3163 - RV Refrigeration Repair
rvrefrigeratorrepair.com > wp-content > uploads > 2016/08 > Norcold...
PDF Norcold. Fuse specifications are found in the. "Specifications" section on page 2 of this man- ual. ... The model 3163 is designed for built-in installation and.
Norcold 3163 3-way refrigerator won't start on propane, what ...
tab-rv.vanillacommunity.com > discussion > norcold-3163-3-way-refr...
Sep 9, 2018 - Norcold 3163 3-way refrigerator won't start on propane, what fixed mine & general diagnostic advice. rajamar Member Posts: 108. September ...
Norcold 3163 Parts/ Products For Sale! - The Norcold Guy
thenorcoldguy.com > norcold-3163-parts
The following parts fit the Norcold 3163 model refrigerators. To determine which product fits your particular model you must know the model and serial number of ...
Norcold 3163 fridge removal and cleaning ยท EuroVan Stuff
1705.net > norcold-3163-removal-cleaning
Feb 22, 2011 - Decided to tackle the job of removing the Norcold fridge (one of our favorite parts of the van) to check just what IS the condition of the burner ...
Do you mean
Refrigerator initially works but when it turns off it doesn't come back on. What is the reason?
Faulty thermostat.
Refrigerators | Answered on Sep 17, 2020
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Refrigerators | Answered on Sep 16, 2020
Sounds like you have an obstruction within the ice maker like ice frozen solid at the dispenser. You could try removing the ice maker and clearing out or cleaning out any stuck ice.
Refrigerators | Answered on Sep 13, 2020
https://www.google.com/search?q=Mr+Freeze+ice+maker+the+drip+cap+leaks&rlz=1C1CHBF_enUS757US757&oq=Mr+Freeze+ice+maker+the+drip+cap+leaks&aqs=chrome..69i57.550j0j4&sourceid=chrome&ie=UTF-8
Refrigerators | Answered on Sep 12, 2020
First, check door operation to determine whether the hinge assemblies are at fault. Some problems of this sort can be solved bt rehanging the existing door.
Refrigerators | Answered on Sep 11, 2020
It is supposed to. The iced water runs until the correct thickness is reached. Then the defrost cycle starts and the ice falls into the hopper. The process starts again and again until the hopper is full. Then the water stops running until ice is removed
Or
it's faulty.
Refrigerators | Answered on Sep 10, 2020
ULINE U-Line 1175BEVS-00 1000 Series 24" Reversible Door Beverage Center Refrigerator with Dual Cooling Zones in Stainless Steel 1175BEVS-00 Logo
2 questions posted
Top ULINE Refrigerators Experts
Marvin
Marvin
john h
Are you an ULINE Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
ULINE Refrigerators
  • ULINE Refrigerators
Most Popular Question
u line beverage cooler indicating e5
  • Refrigerators
