20 Most Recent
Traxxas Slash Questions & Answers
TRXXAS WILL TURN RIGHT BUT NOT LEFT
is the steering servo working ? if so you have to set it back to the center then re attach the steering rod. turn the power off to everything and disconnect everything thats connected to the steering servo. then turn your remote on and set the steering trim on the remote back to center, then turn the power on to your car. the servo will automatically set itself to the center position, and then reattach the steering rods to your servo. make sure your tires are pointing straight forward as well when you screw the stuff back onto the servo. should do it. if the servo isnt working just replace it.
Vxl-3s velineon problem with speed control
This problem is very common with the traxxas vxl 3-s speed control. If you were previously running it in 70 degrees or above without a cooling fan, hobbytown is correct. If you have a fan, or it is cool outside, try your best to return the speed control for a new one.
5/13/2015 9:11:17 AM •
Traxxas Toys
Answered
on May 13, 2015
