20 Most Recent Casio JF-100TE Calculator Questions & Answers
You can't. When you think it is going to shut itself off, press some key.
Casio JF-100TE... | Answered on May 22, 2018
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Casio JF-100TE... | Answered on Jan 13, 2014
Taking the back off The Casio JF-100 calculator is similar to the ...TE. Remove the two screws at the top back. Place a small screwdriver blade along the seam where the back plate fits into the front plate. There are 3 fasteners on each long side and 1 fastener on each of the front and back sides. Find the spot where it's the easiest to separate the back plate from the top plate (there are only two). Carefully twist the blade to cause an opening. Then proceed sequentially around the perimeter releasing each fastener. The front plate will easily separate from the back plate at this time. There are no parts that will fall-out--don't worry. Replace the battery. Press the front and back plates together to snap the fasteners.
Casio JF-100TE... | Answered on Nov 23, 2013
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 6 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 6 should be displayed
Casio JF-100TE... | Answered on Nov 20, 2012
Already answered here: http://www.fixya.com/support/t292440-casio_jf_120er_euro_rate_set
Casio JF-100TE... | Answered on Apr 03, 2010
It is solar powred and will turn off by itself. Don't worry it doesn't cost anything.
Casio JF-100TE... | Answered on Sep 10, 2008
Press the Shift/Mode key and set the Input/Output to MathIO.
Even that will not guarantee that the display will be in root form. Only square roots are possible.
Casio Office... | Answered on May 25, 2020
https://support.casio.com/en/support/answer.php?cid=004004001006&qid=103&num=1
The "E" stands for "Error". This problem can usually be resolved by resetting your calculator. https://sharpcalculators.com/support/troubleshooting/16-troubleshooting/39-what-does-the-e-on-my-display-mean-2
Casio Office... | Answered on Apr 11, 2020
Casio JF-100TE Calculator Logo
17 questions posted
Top Casio Office Equipment & Supplies Experts
Ekse
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
casio jf 100te battery replacement
  • Office Equipment & Supplies
