20 Most Recent JVC HD-70G886 70" Rear Projection HDTV Questions & Answers
Where is the rear bulb??
JVC HD-70G886... | Answered on Jun 22, 2018
You may have a fault in the HDMI cable. Swap it out first.
JVC HD-70G886... | Answered on Jul 05, 2015
You never should have to but if you wanted to you would have to disassemble the entire front. That could be as easy as a few screws or taking the whole thing apart depending on your model.
JVC HD-70G886... | Answered on Aug 23, 2014
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
JVC HD-70G886... | Answered on May 08, 2014
You have a short and likely in the power supply---not a do it yourself repair for most people.
JVC HD-70G886... | Answered on Apr 23, 2012
There are three only three possibility's here, one there is a problem with the HDMI HOOK UP ON THE BACK OF THE TV, SECONDLY IT COULD BE THE DVD PLAYER IS NOT COMPATIBLE WITH THAT TV, AND LASTLY YOU MIGHT NEED TO HAVE THE TV SERVICED FOR SYSTEM ISSUES
JVC HD-70G886... | Answered on Mar 06, 2011
Take several digital pictures of the problem you are having from different distances and angles including a shot that gets the entire television in. It sounds like the panel is bad and perhaps you will be able to negotiate with JVC because that would be a repair more costly than the price of a new television.
JVC HD-70G886... | Answered on Nov 29, 2010
If it would have been a bulb problem you would have a flashing light on the lamp led signalling that it has failed. If the tv is completely dead then the failure is in the power source, and it's massive. The tv must be opened and tested by a qualified person. Time to call a repairman.
JVC HD-70G886... | Answered on Sep 12, 2010
Get some freeze spray from radio shack then try placing a little spray on each chip on the video board and power supply board and each time you spray a chip look for the picture to clear up. When the lines go away you have located the bad IC.
JVC HD-70G886... | Answered on Nov 28, 2008
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
JVC Televison &... | Answered on Feb 12, 2020
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
JVC Televison &... | Answered on Feb 10, 2020
Use the App Search feature.
JVC Televison &... | Answered on Jan 19, 2020
JVC HD-70G886 70" Rear Projection HDTV Logo
Popular Tags
20 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
jvc hd 61g887 went dark
  • Televison & Video
