20 Most Recent Yardworks 225 Ft Slide Track Garden Yard Hose Reel Questions & Answers
Irrelevant. Unidentified object
Garden | Answered 17 hours ago
It flattens the material.
Contact manufacturer for assistance through their web site:
https://www.aosom.com/item/outsunny-10-x-10-steel-and-polycarbonate-hardtop-gazebo-canopy-cover-with-mesh-net-curtains~01-0871.html
Negative comment at web site below suggesting poor instructions and problem assembling.
https://www.wayfair.com/outdoor/pdx/outsunny-10-ft-w-x-10-ft-d-metal-patio-gazebo-otsu1638.html
Garden | Answered Yesterday
google for parts. there are seals gone bad inside it
Request insructions from Northwest Territory.
Garden | Answered 2 days ago
We aren't mind readers, we have absolutely no idea what you have!!!
On most small garden items like trimmers and chainsaws, yes. On mowers with 4 stroke engines, no! Does it have valves? Valves mean 4 stroke, no oil, No valves means 2 stoke, so oil mix.
Google
make model manual
or
make model gas oil mix
Old ones are 20 or 25 to 1, modern are 40 to 50 to 1.
http://manuals.deere.com/cceomview/OMGX20196_H1/Output/Index.html?tM=HO
See section, replacing mower drive belt.
Garden | Answered 3 days ago
With on handle bars or shaft up close to the motor
Multiple causes;
Fuel tank vent. Loosen tank cap and see if problem goes away.
Failing ignition module. Check for spark at time of failure.
Failing afterfire solenoid. Removed solenoid and detach plunger and see if problem goes away.
Garden | Answered on Jul 03, 2020
Strimmer line is consumed constantly in use either by wear against abrasive surfaces or being snagged against stems and suchlike it can't cut through and so tends to break. With lots of patience a lot of those stems can eventually be cut.
Early strimmer users became fed up with the process of stopping work, upturning the machine and releasing more line and starting over and so in order to maintain sales the bump and automatic feed heads were developed.
You description suggests you are using your low powered grass trimmer for heavier work than it is designed for.
Garden | Answered on Jun 30, 2020
Look between your legs!
all 2 strokes take a 50:1 mix. Thats 2.6 ounces of 2 stroke oil, to 1 clean unleaded gallon of gasoline.
Garden | Answered on Jun 25, 2020
I agree, the teflon rings appear to br the only things that wear (aside from the hole size which could wear from water abrasion, but unlikely). That would explain the metal to metal sound you hear at times because the seals prevent wobbling.
It could be a weak spark but most likely it is not receiving the fuel it needs for full throttle operation.
Assuming the fuel is fresh and there isn't an excess of oil this can be tested to some degree by opening the throttle fully and then partially applying the cold start if it can be applied separately or partially covering the intake of the carb with a finger if it can't.
If this improves things it proves the mixture is too lean and it could be a blockage or a matter of adjustment.
One thought occurs - if it was ok before being idle over winter, it is possible the crankshaft oil seals have lost flexibility and air is being drawn past them into the crankcase.
Garden | Answered on Jun 24, 2020
Trigger available on this one stripped down for parts
https://www.ebay.com/itm/Black-Decker-Belt-Sander-7451-TYPE-2-Parts-Sold-Individually-Or-As-Part-Group-/183926335324#viTabs_0
Trigger & Power Cord : The trigger worked well and there should be ample wire left to tie it into your motor. The cord itself has a lot of damage and tape repairs, but I let it be so that the collar and other parts can be used.
Or the other thing you could do is bypass the switch, fill the hole with epoxy putty and put a sliding light switch in the cord near the sander tail.
https://www.amazon.ca/uxcell%C2%AE-Inline-Switch-Toggle-Table/dp/B07P5YW8TG
Yardworks 225 Ft Slide Track Garden Yard Hose Reel Logo
0 questions posted
Top Yardworks Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
View Most Popular
Yardworks Garden
  • Yardworks Garden
Most Popular Question
setting lawm fertilizer yardworks
  • Garden
