20 Most Recent JVC AV-21meu 21" TV Questions & Answers
Hi ,
Check problem is in AV mode only or both AV and RF
If both mode problem is there follow the bellow
Other wise problem May RCA cable (AV cable)
I f you are able to open TV check speaker using a Multimeter (Tv should be OFF) continuity mode,is it shows 2 ohms or below speaker is ok, problem may be audio section of your TV.
Thank you
JVC AV-21meu 21"... | Answered on Apr 22, 2014
The codes for JVC TV to program universal remote are 159, 013, 012, 182, 054, 060, 065, 066, 067, 123, 157, and 158. This depends on the BRAND of the Universal Remote you are using. These codes are compatible with Innovage Universal Remote. For instructions on how to apply this, go to this link:
http://www.ubergizmo.com/2007/04/innovage-jumbo-universal-remote/
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds to click on YES buttonin return. Have a good one!
JVC AV-21meu 21"... | Answered on Jun 06, 2011
If this is a crt type its commonly attributed to high voltage section fault. A bad HOT or bad FBT. But check first it minor component for a faulty one.
JVC AV-21meu 21"... | Answered on Apr 18, 2009
If thhe ic has a crak that you can see then it is no good replace the ic If looks good then look real close where it is soluder ontothe board for little crakes in the soluder where the pins are. I would resolder the ic anyway becouse some thime you cannot see the crakes but the pins are loose. Now there is some capasistors in that cerit also that go bad.You would ned a capasistor checking machine to check these out of cerit.These capasistors that im talking about are usley black with writeing on the side like 10u 25 v this is not for the ones you have in your set just trying to let you know what im talking about. There is a pos and neg side to this kind of cap and they have to be put in just the way they are took out. Try resoludering the ic first then see what happens if it looks ok, if that does not fix it replace the ic and caps. This ic will be mounted to a heatsink by the way.
JVC AV-21meu 21"... | Answered on Mar 09, 2009
How old is this TV?
As Tv's age, the high-voltage suffers and they get darker. You can turn up the screen adjustment on the flyback transformer and buy some time but:
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like Module Exchange at 972-298-1212
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
JVC AV-21meu 21"... | Answered on Jan 19, 2009
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
JVC AV-21meu 21"... | Answered on Aug 01, 2008
Hi there!
The Video circuit or chip that runs it may be at fault. Refer to a repair technician if not familiar with TV repairs. Good Luck, JUS004
JVC AV-21meu 21"... | Answered on Mar 16, 2008
After a long time trying to make this work I finally found a solution yesterday. and it was so simple I almost kicked myself. Now i'm enjoying DSTV on my JVC TV. and the Answer is KODI. find an add on from SLYGUY. you still need to have a subscription.
JVC Televison &... | Answered on Sep 27, 2020
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
JVC Televison &... | Answered on Sep 17, 2020
Use the App Search feature.
JVC Televison &... | Answered on Aug 27, 2020
The Fetch automatic remote setup for a Soniq TV also worked with my older JVC TV, no code needed.
JVC Televison &... | Answered on Jul 10, 2020
Hi, you can try firmware update online or by usb if it isn't in the last version yet.
The other solution is replace the main board (motherboard)
JVC Televison &... | Answered on Jul 05, 2020
You surely meant LED not LCD.
Eliminate any posdible issues with skybox and try using a simple DVD player to a different input port.
JVC Televison &... | Answered on Jul 02, 2020
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ Unlock procedure to many popular brand TVs are given.
JVC Televison &... | Answered on Jul 01, 2020
I don't know but surely if your tv has an option for analogue inputs there will be a range of sockets for the job - phono and/or scart.
If the sockets are there connecting will be intuitive.
Many modern tv sets are compatible only with boxes, converters, decoders and media players that provide a digital output. Analogue to digital converters are available but I can't comment about how successful they are.
I suggest you revisit the user manual of your tv.
JVC Televison &... | Answered on Jun 25, 2020
Televison & Video Logo
16 questions posted
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
universal remote control code jvc
  • Televison & Video
