20 Most Recent JVC AV-36D201 36" TV Questions & Answers
Hi:
Open the television and follow the power cord to the main power supply board the fuse will be near this cords contact plug check for blown 5amp fuse, if fuse is not blown then power supply took a shock and needs repair.
JVC AV-36D201... • Answered on Aug 18, 2010
Unplug the JVC from the power outlet for 10 seconds. Plug the JVC TV back into the power outlet. Hold down both the "Menu" and "Volume Down (-)" buttons for another 10 seconds. Just before releasing these buttons, press and hold the "Power" button.
JVC Televison &... • Answered on May 01, 2021
I found a Portugese version of the user manual for the JVC RX-884VBK at ManualsLib here: https://www.manualslib.com/products/Jvc-Rx-884vbk-3775235.html . Take a look at the sections on using the remote starting around page 65. (There is a section on the CompuLink Features and then a page about using the remote with a VCR. After that, I saw remote control codes.) Most Redi-remotes are programmed with the factory standard codes for an original remote. That means that it will not control other AV devices that are newer than the RX-884VBK. Usually universal remotes are limited to controlling devices that were manufactured/programmed 6 months or more before the remote itself was programmed. I hope this helps. Cindy Wells (Note: I don't read Portugese but used cognates and the adjacent pictures to follow the documentation. I couldn't find any other language versions of this manual.)
JVC Televison &... • Answered on Apr 26, 2021
hdmi is not a channel only a cable from another device
A red flashing light on a JVC TV means that the TV timers function has been activated. When setting the programmable clock it will automatically turn on and turn off your TV at predetermined times.
JVC Televison &... • Answered on Apr 17, 2021
It's not the outage that causes the issue, it is the power surge when it goes, often caused by a lightning strike of 100,000 volts, and also a surge when the power comes back on. If it took out one board, it took them all out, because they are all connected together.Change all the boards, but I bet it still won't work. Claim to your electricity utility company or claim on house insurance.
JVC Televison &... • Answered on Mar 31, 2021
http://electronicshelponline.blogspot.com/ Visit the site linked above. It has circuit diagrams of many popular devices. You can get details there. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
JVC Televison &... • Answered on Mar 18, 2021
Some thing short circuit at its main circuit board. Probably, it should be with its main amplifier section circuit. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
JVC Televison &... • Answered on Mar 12, 2021
After a lamp replacement, you should perform a lamp time reset. Did you done that? If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
JVC Televison &... • Answered on Mar 06, 2021
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
JVC Televison &... • Answered on Feb 28, 2021
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
There might be an issue with your TV"s power supply and the power supply is going bad for your TV and needs to be replaced.
JVC Televison &... • Answered on Feb 27, 2021
What is the model number of your TV? If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
JVC Televison &... • Answered on Feb 26, 2021
JVC AV-36D201 36" TV Logo
5 questions posted
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
wont come house
  • Televison & Video
